Page 20 of 39 FirstFirst ... 10181920212230 ... LastLast
Results 191 to 200 of 381
Thread: Rbl ?
  1. #191
    35
    Default Re: Rbl ?
    Just turn that failed print into a lamp shade for inside.
  2. #192
    Nov 2018
    Houston, Texas
    1,366
    Default Re: Rbl ?
    Quote Originally Posted by fillibar View Post
    Just turn that one into a lamp shade for inside.
    I donít even own a lamp lol
  3. #193
    35
    Default Re: Rbl ?
    Hmm... Good point, not many around our house either. Put a pixel puck in it from the bottom and it will have pretty much the same effect. Just make a base for it to set into with a slot for the power cord.
  4. #194
    Chambersburg, PA
    744
    Default Re: Rbl ?
    Problem solved
    Don't you just Love PVC Pipe
    2016 - No Display
  5. #195
    Nov 2018
    Houston, Texas
    1,366
    Default Re: Rbl ?
    Itís almost as great a product as dis duct tape lol
  6. #196
    Nov 2018
    Houston, Texas
    1,366
    Default Re: Rbl ?
    1 Just confirmed I can fit this in the mini RBL with 6 of these lights with extra room will update the with how extreme the brightness is once I get the new adapter printed to mount them .
    These I imagine would be extremely bright .
  7. #197
    4,248
    Default Re: Rbl ?
    What about the heat generated by those modules?
  8. #198
    Nov 2018
    Houston, Texas
    1,366
    Default Re: Rbl ?
    I will run a test to check but didnít know those put off anymore heat than regular bullet RGB
  9. #199
    4,248
    Default Re: Rbl ?
    Each 5050 puts out almost as much heat as a bullet. There are a lot more of them in there than you had with the bullets.
  10. #200
    Nov 2018
    Houston, Texas
    1,366
    Default Re: Rbl ?
    Gotcha Iíll try it out and see thanks for the heads up
