Page 17 of 39 FirstFirst ... 7151617181927 ... LastLast
Results 161 to 170 of 381
Thread: Rbl ?
  1. #161
    Delaware, OH
    4,380
    Default Re: Rbl ?
    Have you done a cold test on these?
    If not I'd like to suggest you put one in a freezer for a couple of days.
    They spray it with water and put it back in again.
    After a couple more days, take it out and make sure it doesn't break or shatter easily.
  2. #162
    Nov 2018
    Houston, Texas
    1,366
    Default Re: Rbl ?
    Ok but I think different fillament may have diff outcome I use PLA so thatís all I can test ... but will do that for sure .
  3. #163
    Kansas City Missouri
    2,464
    Default Re: Rbl ?
    Yes I used white for bulb
    I got your files and was going to print but it may be a while. My new Ender 3 Pro is giving me fits. I printed out the supplied dog file and I have layer shifts. The first 5 layers were good, then shifted 2mm for a few layers then shifted back and the rest of the print looks awesome. So, I printed again but only the first 15 layers and they looked great so I figured it was a fluke due to being a new printer. Tried printing a cover plate for the back of the display and it's back to shifting again. 1st layer down and then 2nd layer shifts, then 3rd layer shifts. It's driving me nuts.
  4. #164
    Nov 2018
    Houston, Texas
    1,366
    Default Re: Rbl ?
    Iíd check for anything loose or wiggling around . Iíve sat and stared at mine for over an hour to find out I had a loose wheel .
  5. #165
    2,464
    Default Re: Rbl ?
    I've only been at it for about 7.5 hours.
  6. #166
    Nov 2018
    Houston, Texas
    1,366
    Default Re: Rbl ?
    Oh crap good luck
  7. #167
    2,464
    Default Re: Rbl ?
    Oh crap good luck
    I gave up for today. If I had known this printer was this much a PIA I wouldn't have bought it. My Monoprice Mini V2 is superior to this thing.
  8. #168
    Nov 2018
    Houston, Texas
    1,366
    Default Re: Rbl ?
    Sorry youíve had so much problems Iíve had none out of the 3 I got and was considering another literally put together and started printing and theyíve been printing nonstop pretty much since Iíve got them .
  9. #169
    2,464
    Default Re: Rbl ?
    It is what it is. My luck I got a lemon.
  10. #170
    2,464
    Default Re: Rbl ?
    Unfortunately I'm persistent. Decided to give it one more try. I readjusted the "Z" belt and it appears to be going good. On the third layer of a hour print. Cross my fingers. However, the nozzle seems to be dragging on the printed part. I have "Z" enabled but the head when finishing one part shoots over to another part and doesn't hop. Deal with it later. Just hope this layed shift is fixed.
