Page 16 of 41 FirstFirst ... 6141516171826 ... LastLast
Results 151 to 160 of 405
Thread: Rbl ?
  1. #151
    Nov 2018
    Houston, Texas
    1,383
    Default Re: Rbl ?
    Quote Originally Posted by Glycerine View Post
    Those look great!
    Thanks the more I get done the more I like them .
  2. #152
    Nov 2018
    Houston, Texas
    1,383
    Default Re: Rbl ?
    Anyone use these , are they brighter I ordered a batch to try ?
  3. #153
    Nov 2018
    Houston, Texas
    1,383
    Default Re: Rbl ?
    Going by the measurements on the site I ordered , I created an adapter for the mini RBL that should allow for someone to mount 6 of these and still fit inside the neck of the bulb . As I know there are those out there that want super bright lights . I think this might help brighten things up .
  4. #154
    35
    Default Re: Rbl ?
    @wilmar:
    I do not have any tools to measure brightness, but I bought a batch of those a couple weeks ago to try out. They APPEAR very bright, but since they are about 3" (75mm) wide, not including the wires, it would be impossible to fit them in the top of one of these bulbs in a reasonable fashion. The could be put in vertically but that would lose almost all the light from them. If you ran them down in further (again vertically) with a stem so they are right in the bulb itself, that would work but they will probably make for really bright points along the side and a noticeable difference at the top and bottom of the bulb unless you ALSO combined in bullets.
    To be honest I got mine and am now at a bit of a loss as to what to actually do with the ones I bought. I am sure I will come up with something eventually.
  5. #155
    New Jersey
    1,341
    Default Re: Rbl ?
    Yes, I use a similar thing in TLS3001 in the globes of my north poles. They're really no brighter than the TLS3001 ribbon I wrap around the pole. They're diffused being inside the globe and that looks great. I only put 3 of them inside the globe.
    Jeff
  6. #156
    Nov 2018
    Houston, Texas
    1,383
    Default Re: Rbl ?
    Quote Originally Posted by fillibar View Post
    @wilmar:
    Yes Iím running vertically and increased the stem so the entire light would be inside the bulb while still being located at the bottom portion of the bulb .
  7. #157
    Nov 2018
    Houston, Texas
    1,383
    Default Re: Rbl ?
    Jeff
    Also made one for 4 that definitely will fit inside the bulb neck so Iím gonna try 4 and 6 just because ... just because I wanna know lol
  8. #158
    Nov 2018
    Houston, Texas
    1,383
    Default Re: Rbl ?
    I did play with lights last night and got some good Easter colors from them lol
  9. #159
    Jun 2008
    Pompton Plains, NJ
    279
    Default Re: Rbl ?
    What color filament did you use for the bulb? White? I want to get these started
  10. #160
    Nov 2018
    Houston, Texas
    1,383
    Default Re: Rbl ?
    Quote Originally Posted by Ponddude View Post
    Yes I used white for bulb
