Results 1 to 7 of 7
Thread: FPP Master/remote
    Dec 2019
    134
    Default FPP Master/remote
    After reading through the FPP manual, I'd like clarification on something. I will be running FPP on a Pi, and will use at least one controller that uses a PocketBeagle with FPP on it as well. Can both the Pi and controller run FPP as master or MUST the controller run as remote and only the Pi be master?
    Nov 2014
    Close to Hillsboro, OR
    512
    Default Re: FPP Master/remote
    Is there a specific need that requires you to have 2 Masters?
    Irmo, SC
    75
    This would depend are they both controlling lights that are part of one show the must run in sync or is one controlling something like a matrix that displays images or messages separate from the main show. If the pocket beagle is controlling lights that should be in sync with the lights on the pi then you will want to use master on one and remote on the other.
    Dec 2019
    134
    I don't know, that's part of why I'm asking the question. I'm just getting into this stuff and wasn't sure how things should be configured.
    Dec 2019
    134
    Quote Originally Posted by blackramair View Post
    Ok, thanks! The controllers would be controlling pixels that are all part of the main show.
    Irmo, SC
    75
    Quote Originally Posted by Glycerine View Post
    Since each beaglebone will be controlling lights that are all part of the main show then you will want to use master and remote. A reminder that only the master will play the audio out, so if you have sound your audio devices will be connected to your master and not your remote.
    Dec 2019
    134
    Thank you.
