Results 1 to 10 of 11
Thread: OLED Raspberry Pi
    Dec 2019
    134
    Default OLED Raspberry Pi
    When using a raspberry pi as my player, running FPP, I can just connect a 4 pin OLED (128X64 I2C SSD1306) to pins 1,3,5 and 6 on the pi, then enable the OLED in the FPP settings and it will work, correct?
    Dec 2019
    134
    Default Re: OLED Raspberry Pi
    Also, would I need to do anything special to connect an RTC to the same I2C bus as the OLED?
    4,299
    Yes the I2C buss allows multiple devices at the same time.
    Framingham, MA
    510
    Yes... You can connect them both.
    That said, I DO sell a hat specifically for this purpose and an RTC is an option: https://kulplights.com/product/pi-oled/
    Dan Kulp
    Dec 2019
    134
    Thanks. I'll look into your hat, but I'll probably just rig something up myself for now.
    Nov 2018
    Houston, Texas
    1,482
    Would the hat work for the pi zero wh as well or no ?
    Nov 2013
    Morganton,North Carolina
    1,697
    This ^^^^
    (1)Falcon F16V3
    (1)Renard SS16
    (1)Renard SS24
    (1)EDM-LCD-CS-EP
    (20)P10 Panels
    WIKI
    Become A Supporting Member
    Falcon Christmas
    Renard Controllers
    4,299
    The expansion connector for the PI zero and the PI 2,3 etc are all the same. The issue might be if the hat touches something on the pi. Easily solved with a thin sheet of plastic.
    Nov 2018
    Houston, Texas
    1,482
    Ok gotcha if my ip changes again having that would show me correct ?
    Dec 2019
    134
    Correct!
