Results 11 to 20 of 23
Thread: Beginner friendly matrix ?
    Nov 2018
    Houston, Texas
    2,077
    Default Re: Beginner friendly matrix ?
    Reasoning is I already have two pi zero w on hand one is set up with FPP already to run show.
    4,926
    Your PI zero can run two ports via a hat. If you add the Ethernet hat to the stack it can drive the two local ports AND 10,000 more pixels via controllers like the Falcon and Sandevice pixel controllers.
    Nov 2018
    Houston, Texas
    2,077
    I have this
    4,926
    You add the pi zero pixel hat to that stack if you want to drive up to two directly connected strings. Via the Ethernet CAT6 connection you can drive multiple E1.31 based pixel controllers.
    Nov 2018
    Houston, Texas
    2,077
    I tried the pixel hat for the 2 local ports and sadly I was unable to get that part to work but everything else worked fine
    4,926
    A 1:1 session would take care of that pretty quickly.
    Nov 2018
    Houston, Texas
    2,077
    That would be awesome
    Nov 2018
    Houston, Texas
    2,077
    Default Beginner friendly matrix ?
    Well DO NOT buy one of these and try to put a pixel hat on top of it without placing something between the Ethernet housing and bottom of hat .
    Or you’ll be sending up smoke signals
    Kimberly, WI
    313
    Oh no... you let the magic smoke escape.....
    9,338
    "Beginner friendly" and "matrix" don't work well together in the same sentence.
    http://digwdf.org/store/
