Results 1 to 10 of 25
Thread: Esp Code for various modules
    6,371
    Default Esp Code for various modules
    Thought I would start a thread for sharing working sketches .
    This is for esp8266 wemos . Uses FastLed & older E131
    May also work on Esp-01, not tested
    Code:
      E131_Test.ino - Simple sketch to listen for E1.31
      Project: E131 ESP8266 and FastLed
      Copyright (c)  Shelby Merrick
      http://www.forkineye.com
       This program is provided free for you to use in any way that you wish,
       subject to the laws and regulations where you are using it.  Due diligence
       is strongly suggested before using this code.  Please give credit where due.
       The Author makes no warranty of any kind, express or implied, with regard
       to this program or the documentation contained in this document.  The
       Author shall not be liable in any event for incidental or consequential
       damages in connection with, or arising out of, the furnishing, performance
       or use of these programs.
    #include <ESP8266WiFi.h>
    #include <E131.h>
    #include <FastLED.h>
    #define UNIVERSE 1                      // First DMX Universe to listen for
    #define CHANNEL_START 1
    #define DATA_PIN 2
    #define NUM_LEDS 170
    CRGB newLeds[NUM_LEDS];
    const char ssid[] = "SSID";         // Replace with your SSID
    const char passphrase[] = "PASSWORD";   // Replace with your WPA2 passphrase
    // ESPAsyncE131 instance with UNIVERSE_COUNT buffer slots
    E131 e131;
    void setup() {
      Serial.begin(115200);
      delay(10);
      FastLED.addLeds<WS2812B, DATA_PIN, GRB>(newLeds, NUM_LEDS);
      // Make sure you're in station mode
      WiFi.mode(WIFI_STA);
      Serial.println("");
      Serial.print(F("Connecting to "));
      Serial.print(ssid);
      if (passphrase != NULL)
        WiFi.begin(ssid, passphrase);
      else
        WiFi.begin(ssid);
        delay(500);
        Serial.print(".");
      Serial.println("");
      Serial.print(F("Connected with IP: "));
      Serial.println(WiFi.localIP());
      // Choose one to begin listening for E1.31 data
      //if (e131.begin(E131_UNICAST))                               // Listen via Unicast
      //if (e131.begin(E131_MULTICAST, UNIVERSE, UNIVERSE_COUNT))   // Listen via Multicast
      e131.beginMulticast(ssid, passphrase, UNIVERSE);
      Serial.println(F("Listening for data..."));
    void loop() {
      if (e131.parsePacket()) {
        if (e131.universe == 1) {
          for (int i = 0; i < NUM_LEDS; i++) {
            int j = i * 3 + (CHANNEL_START - 1);
            newLeds[i] = (i, (CRGB(e131.data[j], e131.data[j + 1], e131.data[j + 2])));
          FastLED.show();
    6,371
    Default Re: Esp Code for various modules
    Esp8266 Wemos, EspAsyncE131 , FastLed
    May also work on esp-01 , not tested .
    Code:
      Project: ESPAsyncE131  ESP8266 and FastLed
      Copyright (c) 2019 Shelby Merrick
    #include <ESPAsyncE131.h>
    #define UNIVERSE_COUNT 2
    #define DATA_PIN 2
    ESPAsyncE131 e131(UNIVERSE_COUNT);
    void setup() {
      delay(10);
      Serial.println("");
      Serial.print(ssid);
      else
        WiFi.begin(ssid);
        delay(500);
        Serial.print(".");
      Serial.println("");
      else
        Serial.println(F("*** e131.begin failed ***"));
    void loop() {
      if (!e131.isEmpty()) {
        e131_packet_t packet;
        e131.pull(&packet);     // Pull packet from ring buffer
        uint16_t universe = htons(packet.universe);
        if (universe == 1) {
          if (packet.property_values[(CHANNEL_START - 1)] < NUM_LEDS) {
            for (int n = 0; n < NUM_LEDS; n++) {
              int j = n * 3 + (CHANNEL_START);
              newLeds[n] = (n, (CRGB(packet.property_values[j] , packet.property_values[j + 1], packet.property_values[j + 2])));
              //Serial.println(packet.property_values[j]);
            FastLED.show();
            /*   Serial.printf("Universe %u / %u Channels | Packet#: %u / Errors: %u / CH1: %u\n",
                       htons(packet.universe),                 // The Universe for this packet
                       htons(packet.property_value_count) - 1, // Start code is ignored, we're interested in dimmer data
                       e131.stats.num_packets,                 // Packet counter
                       e131.stats.packet_errors,               // Packet error counter
                       packet.property_values[1]);             // Dimmer data for Channel 1     */
    6,371
    Esp8266 Wemos, EspAsyncE131, NeoPixelBus
    May work on Esp-01 , not tested
    Code:
      E131_Test.ino - Simple sketch to listen for E1.31 data on an ESP32
                       and print some statistics.
      Project: ESPAsyncE131 - Asynchronous E.131 (sACN) library for Arduino ESP8266
    #include <NeoPixelBus.h>
    #define UNIVERSE_COUNT 2          // Total number of Universes to listen for, starting at UNIVERSE
    const uint16_t PixelCount = 170; // this example assumes 4 pixels, making it smaller will cause a failure
    const uint8_t PixelPin = 2;  // make sure to set this to the correct pin, ignored for Esp8266
    NeoPixelBus<NeoGrbFeature, NeoEsp8266BitBangWs2812xMethod> strip(PixelCount, PixelPin);
    void setup() {
      delay(10);
      Serial.println("");
      Serial.print(ssid);
      else
        WiFi.begin(ssid);
        delay(500);
        Serial.print(".");
      Serial.println("");
     /* Initialize output */
        pinMode(PixelPin, OUTPUT);
        digitalWrite(PixelPin, LOW);
     // this resets all the neopixels to an off state
        strip.Begin();
        strip.Show();
      if (e131.begin(E131_MULTICAST, UNIVERSE, UNIVERSE_COUNT));   // Listen via Multicast
    void loop() {
         if (packet.property_values[(CHANNEL_START - 1)] < PixelCount) {
          for (int i = 0; i < PixelCount; i++) {
                int j = i * 3 + (CHANNEL_START );
                  strip.SetPixelColor(i, (RgbColor(packet.property_values[j], packet.property_values[j+1], packet.property_values[j+2])));
                Serial.println(packet.property_values[j] );;
                strip.Show();
    6,371
    ESP32 ,EspAsyncE131 & NeoPixelBus (This provides 2 functional GPIO * 2 Universes as configured , with the possibly of more through experimentation )
    Code:
      All credits to :
      Shelby Merrick for his E131
      Michael Miller for the NeoPixel_Bus
      Project: ESPAsyncE131 - Asynchronous E.131 (sACN) library for Arduino ESP8266 and ESP32
      NeoPixelBus Test
      https://github.com/Makuna/NeoPixelBus/wiki/ESP8266-NeoMethods
    #include <WiFi.h>
    #define CHANNEL_START_A 1
    #define UNIVERSE_COUNT 3
    #define CHANNEL_START_B 1
    const uint16_t PixelCount1 = 81; // this example assumes 4 pixels, making it smaller will cause a failure
    const uint8_t PixelPin1 = 12;  // make sure to set this to the correct pin, ignored for Esp8266
    const uint16_t PixelCount2 = 81; // this example assumes 4 pixels, making it smaller will cause a failure
    const uint8_t PixelPin2 = 15;  // make sure to set this to the correct pin, ignored for Esp8266
    ESPAsyncE131 e131(3);
    NeoPixelBus<NeoGrbFeature, NeoEsp32I2s0Ws2812xMethod> strip1(PixelCount1, PixelPin1);
    NeoPixelBus<NeoGrbFeature, NeoEsp32Rmt0800KbpsMethod> strip2(PixelCount2, PixelPin2);
    void setup() {
      delay(10);
      Serial.println("");
      Serial.print(ssid);
      else
        WiFi.begin(ssid);
        delay(500);
        Serial.print(".");
      Serial.println("");
      strip1.Begin();
      strip1.Show();
      strip2.Begin();
      strip2.Show();
    void loop() {
      while (!e131.isEmpty()) {
          //if (packet.property_values[(CHANNEL_START_A - 1)] < PixelCount1) {
            for (int i = 0; i < PixelCount1; i++) {
              int j = i * 3 + (CHANNEL_START_A );
              strip1.SetPixelColor(i, (RgbColor(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j + 2])));
            strip1.Show();
        if ((universe == 2) && (packet.property_values[(CHANNEL_START_B - 1)] == (packet.property_values[0]))) {   << Change the (packet.property_values "0 ") to suit your pixel count >>
            for (int i = 0; i < PixelCount2; i++) {
              int j = i * 3 + (CHANNEL_START_B );
              strip2.SetPixelColor(i, (RgbColor(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j + 2])));
              Serial.println(packet.property_values[j + 1] );
            strip2.Show();
    6,371
    Enjoy ( ͡ ͜ʖ ͡)
    UK S80 postcode
    1,475
    Hi, I haven’t had try these yet but great to see working code posted.
    6,371
    i could not find any code online for the Esp32
    Thanks to Michael Miller and his NeoPixelBus I was able to see some blinky .
    It would be awesome to see the TLS made to work with these modules :
    6,371
    Esp32, NeoPixelBus, I2s, & 2 GPIO
    This is the one of the best configurations that has worked so far !
    One hurdle I have overcome with figuring out the coding is that there is a huge difference between universe & UNIVERSE .
    Code:
      All credits to :
      NeoPixelTest
    #include <WiFi.h>
    const uint16_t PixelCount1 = 170; // this example assumes 4 pixels, making it smaller will cause a failure
    const uint16_t PixelCount2 = 170; // this example assumes 4 pixels, making it smaller will cause a failure
    //NeoPixelBus<NeoGrbFeature, NeoEsp32Rmt0800KbpsMethod> strip1(PixelCount1, PixelPin1);
    //NeoPixelBus<NeoGrbFeature, NeoEsp32Rmt1800KbpsMethod> strip2(PixelCount2, PixelPin2);
    //NeoPixelBus<NeoGrbFeature, NeoEsp32Rmt2800KbpsMethod> strip3(PixelCount3, PixelPin3);
    //NeoPixelBus<NeoGrbFeature, NeoEsp32BitBangWs2813Method> strip3(PixelCount3, PixelPin3);
    NeoPixelBus<NeoGrbFeature, NeoEsp32I2s1800KbpsMethod> strip1(PixelCount1, PixelPin1);
    NeoPixelBus<NeoGrbFeature, NeoEsp32I2s0800KbpsMethod> strip2(PixelCount2, PixelPin2);
    void setup() {
      delay(10);
      Serial.println("");
      Serial.print(ssid);
      else
        WiFi.begin(ssid);
        delay(500);
        Serial.print(".");
      Serial.println("");
      strip1.Begin();
      strip1.Show();
      strip2.Begin();
      strip2.Show();
      //if (e131.begin(E131_UNICAST));                              // Listen via Unicast
    void loop() {
            //Serial.println(packet.property_values[j] );
          //strip1.Dirty();
          strip1.Show();
          //if (packet.property_values[(CHANNEL_START_B - 1)] < PixelCount2) {
            //Serial.println(packet.property_values[j + 1] );
          //strip2.Dirty();
          strip2.Show();
    6,371
    Esp32, Esp8266 , EspAsyncE131 , FastLed 2* GPIO Unicast
    Also works with the old E131 version for esp8266
    Code:
    //#include <ESP8266WiFi.h> // Uncomment for esp8666 & comment out WiFi.h
    #include <WiFi.h>           // Uncomment for esp32 & comment out ESP8266WiFi.h
    #define NUM_LEDS_PER_STRIP_B 81
    #define NUM_LEDS_PER_STRIP_A 81
    #define UNIVERSE  1
    #define DATA_PIN 15
    CRGB newLeds[NUM_LEDS_PER_STRIP_B];
    CRGB oldLeds[NUM_LEDS_PER_STRIP_A];
    ESPAsyncE131 e131(10);
    void setup() {
      delay(10);
      FastLED.addLeds<WS2812B, DATA_PIN, GRB>(newLeds, NUM_LEDS_PER_STRIP_B);
      FastLED.addLeds<NEOPIXEL, 5>(oldLeds, NUM_LEDS_PER_STRIP_A);
      Serial.println("");
      Serial.print(ssid);
      else
        WiFi.begin(ssid);
        delay(500);
        Serial.print(".");
      Serial.println("");
      //e131.beginMulticast(ssid, passphrase,  );
    void loop() {
            for (int i = 0; i < NUM_LEDS_PER_STRIP_B; i++) {
               newLeds[i] = (i, (CRGB(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j + 2])));
            FastLED.show();
        if ((universe == 2) && (packet.property_values[(CHANNEL_START_B - 1)] == (packet.property_values[245]))) {
               for (int i = 0; i < NUM_LEDS_PER_STRIP_A; i++) {
              oldLeds[i] = (i, (CRGB(packet.property_values[j], packet.property_values[j + 1], packet.property_values[j + 2])));
            FastLED.show();
    6,371
    *************SOLVED ***********
    6 GPIO on the Esp32 dev board is all I can do for pixel output .
    more learning to do
