Thread: EDM power supply
    14
    Default EDM power supply
    I just got a new to me EDM, and it did not come with a power supply. (I knew that)
    The specs call for a regulated ps, so what do you who have an EDM use??
    I have seen several on Amazon, but I want to make sure I get a clean one!!
    A link would be great if you have one you like.
    Thanks in advance.
    óCHUCK
    Kansas City Missouri
    2,425
    Default Re: EDM power supply
    Quote Originally Posted by ghostssx View Post
    Thanks in advance.
    —CHUCK
    Mine came with a 12 volt 1amp supply. Been using it for 3 years without an issue.
    4,195
    Mine came with a wallwart. Not fancy and the power is not particularly clean. I suspect a 2A wallwart (1A is needed) would give relatively clean power for you.
