Results 1 to 10 of 12
Thread: ESP Async E131 test.ino
    6,322
    Default ESP Async E131 test.ino
    Ignoring all my prior posts on the E131 topics as I just noticed my error posting .
    I was too focused on the esp32 in experimenting with this sketch that I failed to test on esp8266 until today .
    Voila the code works excellently .
    I cannot say the same for the esp32, but it does work on that module also , with artifacts that I cannot understand why .
    Thanks Shelby for making this to experiment with !
    6,322
    Default Re: ESP Async E131 test.ino
    I can see now why there is 0 response to the Esp32 questions etc that I have posted .
    Well I finally cracked this awesome piece of hardware and now have the Async E131 fully functioning . The Adafruit_NeoPixel lib is not up to the task even though they suggest that it supports The Esp32 .
    At the start of this endeavour I searched and searched for any and all reference to the Esp32 and e131 . What I found was 1 single sketch from a member at this forum .
    Solution -> Neopixel_bus !
    Woot
    6,322
    Could someone give me a clue as to how to expose Universe #2 ?
    I am not clear on how to actually get the packet info specific .
    Thanks in advance .
    4,197
    what does expose mean?
    6,322
    Hi Martin .
    I am trying to apply Universe 2 to a Gpio without luck .
    Universe 1 works great , but am struggling with #2
    1,251
    Universe 2 should be just like universe 1. You check for the universe in the data header and process it appropriately. The universe is sent as part of the packet.
    https://www.diychristmas.org/wiki/in...itle=Protocols
    6,322
    It appears there is no way to #define more than 1 UNIVERSE without having the higher # take precedence.
    If # define UNIVERSE 1
    # define UNIVERSE 2
    Universe 1 never gets processed as the // First DMX Universe to listen for always seems to start at universe 2 .
    Is this the design and workings of the ring buffer ? Or having the addition of #define UNIVERSE_COUNT ?
    Either way , this sorta dampen hopes of this ever working like the previous E131 with multiple output capability .
    1,251
    I thought you wanted to pull out the universe separately for some reason. In either case, I would assume you can get the data you need by following along with the example in the github.
    #define UNIVERSE 1 // First DMX Universe to listen for
    #define UNIVERSE_COUNT 2 // Total number of Universes to listen for, starting at UNIVERSE
    After the e131.pull(&packet); you now have data. Check the universe (packet.universe) and then the data will be in packet.property_values[1] (this being the first channel). Use the packet.property_values as you need.
    6,322
    Thanks Mike
    I have that all sorted . The issue remains that I cannot seem to break away from the pipe created by #define UNIVERSE_COUNT
    It seems as though this may be by design to only be a single Pin application .
    In other words , this is no longer possible as far as I am capable . ( which doesn't say much )
    Code:
    #define NUM_PIXELS_A 600 /* roof Number of pixels */
    #define UNIVERSE 1 /* Universe to listen for */
    #define CHANNEL_START_A 1 /* Channel to start listening at */
    #define DATA_PIN_A 5 /* Pixel output - GPIO5 / nodeMCU D1 */
    #define NUM_PIXELS_B 123/* star Number of pixels */
    #define UNIVERSE 5 /* Universe to listen for */
    #define CHANNEL_START_B 1/* Channel to start listening at */
    #define DATA_PIN_B 4 /* Pixel output - GPIO4 / nodeMCU D2 */
    6,322
    MikeKrebs , your are my hero today
    Thanks to you , I figured out how to break out of the pipe
    I can now use multiple Gpio on the Esp32 YAhoooooooooooooooooo!!!!!!!
    Woot
