Results 1 to 8 of 8
Thread: Vixen keeps closing
    Nov 2018
    Houston, Texas
    1,175
    Default Vixen keeps closing
    Having an issue with setup preview configuration. Every time I try to configure a multi point string for roof line it keeps closing vixen completely soon as I finish the string , havenít had this problem before .
    Nov 2018
    Houston, Texas
    1,175
    Default Re: Vixen keeps closing
    Not sure what I was doing wrong or what, but after about 10 tries itís now working .
    4,200
    Please make a snapshot of your logs and send them to VixenLights as a defect. The team may be able to figure out what was going wrong.
    Nov 2018
    Houston, Texas
    1,175
    Not familiar with how to find the logs sorry
    Nov 2018
    Houston, Texas
    1,175
    Found logs
    Nov 2018
    Houston, Texas
    1,175
    After reading logs I believe itís because I was in wrong profile that the controllers I was testing were not set up on yet . I have a profile that I use to learn and play with without messing up the main main . My mistake not a software issue . Thanks
    4,200
    Yes there is a software mistake here. The program should not close on you just because you have a configuration error. It should tell you that something is wrong so you can fix it. I would still send the logs to the team so they can make the error handling more friendly.
    Nov 2018
    Houston, Texas
    1,175
    Ok thanks
