Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Embedding power supplies
    1,283
    Default Re: Embedding power supplies
    DirkNerkle used quite a few of those style of devices. One issue he had was low temperature performance. I think he used a c7 bulb to warm them up.
    6,370
    Heat does not appear to be an issue -> https://www.youtube.com/watch?v=FK-cYR32zGA
    6,370
    I have, but 24V - the problem was they didn't have any adjustment. One had a 26V output. It worked, but I didn't like feeding 26V to a 24V application. Hey....still running a year later.
    Thank you for this post . It gave me the idea to search for a dual purpose power supply and sure enough there it is .
    1,283
    It is not heat that is the problem - it is cold. Specs on the latest link are -20C or only -4F. If you don't expect below zero temps (F) inside the container holding the PS you should be good.
    New Jersey
    1,341
    Have you considered the regulated 12V pixels. I now running/testing a 100 pixel strand on a 24V PS. A few hundred hours at 100% white.
    Where'd you get 'em? I posted about a prop I want to make and was wondering if the 12v nodes would run at 24v...
    Jeff
    Folsom, CA, USA
    2,122
    Jeff
    The ones I'm testing at 24V now were purchased from DIYLEDEXPRESS in 2018. I think most regulated Pixels today are 7-28V rated, maybe 30V.
    You will need to ask if they are regulated and at what range, if not posted.
    In Lights Therapy
