Results 1 to 10 of 11
Thread: Looking to trade
    Nov 2018
    Houston, Texas
    872
    Default Looking to trade
    Canceled thanks to angus and grumpy for the support .also may have found another controller.
    BRAND NEW
    NanoStation loco m2
    Edge Router-X
    Too complicated for me
    Would like to trade for a good e682 or equivalent. Send message if interested
    Sep 2013
    Norwalk, Iowa
    235
    Default Re: Looking to trade
    BRAND NEW
    NanoStation loco m2
    Edge Router-X
    Is that a poe capable switch?
    Sent from my SM-G930P using Tapatalk
    Nov 2018
    Houston, Texas
    872
    Yes has Poe on both items
    Sep 2013
    Norwalk, Iowa
    235
    Anything else youd be looking for?
    Nov 2018
    Houston, Texas
    872
    Not sure really as everything Iíve tried so far I canít seem to get working except for the one e682 I have and one is not enough.
    6,253
    Start with your edge x router and follow the instructions to get it working first .
    Get a thorough understanding of how it works first then move to adding your m2 as a wifi ap .
    Small steps , you are not in a hurry !
    As Dirk said , setup the router as DHCP.
    Static IP Address
    1. Connect an Ethernet cable from the Ethernet port on
    your computer to the port labeled eth0/PoE In on the
    EdgeRouter. If you are using PoE, then connect your
    computer to the PoE switch or adapter.
    2. Configure the Ethernet adapter on your host system with a
    static IP address on the 192.168.1.x subnet.<<<<<<<<< this is what you configure your network adapter on your pc
    you can substitute the x with 2,3,4,........etc
    the subnet 255.255.255.0
    So something like this for your Pc ipv4
    Use the following address
    ip address 192.168.1.10
    gateway 192.168.1.1
    3. Launch your web browser. Type https://192.168.1.1 in the
    address field, and press enter (PC) or return (Mac).
    4. The login screen will appear. Enter ubnt in the Username
    and Password fields. Read the Ubiquiti License Agreement,
    and check the box next to I agree to the terms of this License
    Agreement to accept it. Click Login.
    Oct 2016
    80
    I think I have a 682 and know I haven't used it. I will check tomorrow if you really want to trade this for one.
    Edit: I have a 6804 not the 682. I'm trying to figure out how to delete this post to not clutter your thread but having no luck.
    Folsom, CA, USA
    2,113
    Wilmer, you have several months to learn how to setup these devices. You have them learn them. Just take notes as you go. and store them under the router.
    There are a lot of great network folks here that would love to help, but they are more focused in Super Bowl than this site. If you join the xLight online Wednesday afternoon online conferences, they can walk you thru it. Maybe someone can post the details to get online with them....I have it but not where I can access
    In Lights Therapy
    6,253
    https://dl.ubnt.com/guides/edgemax/E...r_ER-X_QSG.pdf
    If you don't have the poe adapter , use eth1,eth2 or eth3 instead of eth0 to connect your pc .
    This cannot be that difficult to figure out .
    After you have used the method to login and setup your router , you will need to reset your Pc's network adapter to obtain ip address automatically
    BTW I am learning from your thread here also , don't give up !
    Nov 2018
    Houston, Texas
    872
    Quote Originally Posted by lugnut68f View Post
    No worries but if your interested in selling the 804 I may be interested in purchasing.
