Results 1 to 2 of 2
Thread: Possible candy cane idea?
    2
    Default Possible candy cane idea?
    While replacing 4 foot CFL with LED, i notice safety tubing which OSHA insist on having with CFL in a industrial setting. One of the lights was in a heated area and bent very easily to the shape of a circle. Being clear tubing if you was to spray frosted clear spray paint and wrapped or painted stripes on it, I am pretty sure this could work very well on a couple of ideas. Has any one tried this approach?
    https://www.homedepot.com/p/Lithonia...B&gclsrc=aw.ds
    4,130
    Default Re: Possible candy cane idea?
    Dont know about candy canes but the 8' version might make a great arch instead of PEX tubing. Heat it up on the driveway in the summer and bend it as needed.
