Results 1 to 9 of 9
Thread: first year doing my own
    Dec 2019
    6
    Default first year doing my own
    I have purchased a mega 2560 and some SSR boards for 48 channels. my issue is Im using xlights so i can run videos and my seq thru xscheduler together. i will be using my laptop to run the show and i only have ac lights. I have searched the forums and could not find a code for xlights. is there anyone using xlights and arduino? would anyone be willing to share their code?
    South Carolina
    102
    Default Re: first year doing my own
    I'm not familiar with xlights but what sketch are you using ? I use vixen lights and the sketch I'm using works fine I just set it up as a generic controller http://doityourselfchristmas.com/for...th-Random-mode
    4,137
    xlights, vixen, lor, pretty much irrelavent. What serial protocol are YOU planning to use to go from the show player to your controller? That drives the sketch and the settings on the show player. It sounds like you may want generic serial (I would suggest the renard protocol but...).
    Dec 2019
    6
    That is the code I plan on trying if there is no other one for xlights just to see if i can modify and get it working. I just don’t know much about the coding
    Dec 2019
    6
    I plan on using xschedule on com3 is that what your asking?
    4,137
    Quote Originally Posted by bmuhlenbruch View Post
    Taht is part of it. What protocol are you going to use on com3
    Southern California
    910
    I am just starting to learn xLights and have not tried to connect my Arduinos yet but I understand that there is a controller option that you can select that will output the data using the Renard protocol. The controller type would be USB with the Renard option selected. I will try to perform some testing within the next few days. I have to assume that the output data stream is compatible with Renard based controllers, so, I may be able to use one of the sketches that I had posted on this site that will take a Renard data stream and control AC or DC lights from an Arduino MEGA. You can find the sketches here - http://doityourselfchristmas.com/for...article+renard.
    If you beat me to the testing, please report your experiences here.
    Kevin
    4,137
    Good choice. The Renard protocol is more stable than the generic serial protocol.
    Dec 2019
    6
    thanks i will try this
