Thread: What is the best (read that: easiest) way to patch together three panels side-by-side
    Jan 2018
    7
    Default What is the best (read that: easiest) way to patch together three panels side-by-side
    I have three 20 x 20 panels (net lights, actually) with a horizontal string orientation. I need to place them side-by side and have them behave as a single prop, even though each is fed by a different Falcon F16V3 controller output. I could do it by creating interleaved sub-strings, but this would be VERY tedious. I could create a 60 x 20 display in the preview and make each string in the preview a combination of three rows of pixels, one row from each panel (see attachment). Is there a better way?
    4,130
    Default Re: What is the best (read that: easiest) way to patch together three panels side-by-
    Vixen is designed so that you do NOT drag prop design problems into your Element definitions and complicate your sequencing. Make one large grid with the total number of rows and columns your prop is providing. Then on the patching page you can assign the strings to the proper universes and send them to appropriate F16s.
    2,794
    lrhorer - Are you saying you have 3 matrix panels, butted up against each other at the vertical ends, and the zig zags are horizontal for each?
    This means your first line (left to right) covers only 1/3 of the whole before it zigs back (right to left). Once the lines on the first third of the matrix is complete, you jump down and start on the second?
    I can see where this might be a bit of a problem. Manual patching may be your only alternative.
    BTW - This would be easy if the matrix panels were wired bottom-to-top-to-bottom (vertical).
    Live, Laugh, Love.
    Jan 2018
    7
    That is far from easy. Ultimately, it may be the only smooth way to handle it, but it means each, individual strand must be assigned separately in a jogged fashion. That is 60 individual, non-sequential strand assignments across 20 rows. 'Kind of a nightmare, really.
    It's not separate F16s. It is three ports on a single F16, 400 pixels each.
    Jan 2018
    7
    No, the opposite. The panels are oriented horizontally, with each prop row consisting of one row from each of the panels, left to right.
    Correct.
    Well, no. It doesn't zig-zag. All the rows are numbered from left to right, both physically and logically.
    Physically, yes. Since these are F16 controllers, I could create sub-strings and jump the start of each virtual string by 41 nodes. Another alternative is to make the numbering sequential in the F16 and make the patches in each row jump by 400 and then 800.
    No, there are several others. Indeed, aggregating the prop in the preview does work somewhat, but not as well as I would like.
    No. In fact, I started out that way, but it caused several issues both physically and in Vixen, so I rotated them.
    7,958
    The other thing you can do is just define one output controller in vixen that sends data to all of the physical controllers. You'd need to use multicast for this. Then when you set up the string outputs on the controller config pages, you just assign it to the corresponding universe/start channel for each range of pixels.
    Jan 2018
    7
    Um, you must be missing what I am trying to do. This prop is a hedge covered with a net light, which is a matrix of pixels. It is too large (1200 pixels) to be controlled by a single port on the Falcon F16v3 controller which feeds it, which has a limit of 1024 pixels per port. Consequently, the matrix is divided up into three sections, each 20 x 20 pixels, with each section fed by a single port.
    I went ahead and defined the matrix as a single 60 x 20 unit in Vixen, assigning addresses 2701 - 6300 of one controller to the matrix. In the F16, I created 20 virtual strings under each of the three ports, and assigned 2701 - 2760 to the first virtual string of the first port, 2881 - 2940 to the second virtual string, 3061 - 3120 to the third, etc. On the second port, I assigned 2761 - 2820 to the first virtual string, 2941 - 3000 to the second, etc. Finally, I started the first virtual string on the third port at 2821 through 2880, and so forth, interleaving the address ranges across the three ports in groups of 20 nodes.
    This makes Vixen completely agnostic of the physical layout of the net, which of course makes Vixen very happy. The net is down for modification right now. I will see how it looks tomorrow night.
    2,794
    Interesting.
    Live, Laugh, Love.
    Nov 2018
    Houston, Texas
    835
    Wish I knew what you just said hahaha
