Results 1 to 5 of 5
Thread: HP power supply dimensions
    Jan 2018
    233
    Default HP power supply dimensions
    Can some one tell me the dimensions of a 1200 watt hp server power supply with a break out board? I have seen 3 different dimensions listed for this thing so I would like to know the real dimensions so I can plan co stroller set ups to make sure they will work. Actually thinking I may redesign a mount to put them in a fence post.
    Feb 2017
    307
    Default Re: HP power supply dimensions
    9.5" long x 3.5" wide and 1.5" thick. The breakout board adds an extra inch to the length and puts you at 10.5", but you need at least 1/2" more to have room to connect the wires. I would say you need 11.5 to 12" in length to play ot safe. You can use angled power supply cords to save on room too.
    The 750watt and 1200watt supplies are exactly the same size, and they are very similar in size to a 350watt meanwell supply.
    Personally I think the server supplies are the best way to go.
    Dale P.
    Feb 2017
    307
    Just an FYI, I bought my breakout board off from Amazon for 14.99. Other boards may be larger than mine.
    Delaware, OH
    4,364
    In case anyone is interested, I designed a breakout board that may be of interest/use...
    http://doityourselfchristmas.com/for...755#post490755
    Jan 2018
    233
    Quote Originally Posted by DaleP View Post
    Dale P.
    Perfect, thank you. So i may not have to modify the JD creation Fence post mount at all. Couple years back i bought one of the Dell server power supplies to use as a bench PSU, but they are longer then the HP Ones. Gonna upgrade to a Falcon F48 this year and would rather run 1 supply then 2, and thanks to me forgetting to fully close an enclosure, 2 of PSU's are now done for.
