Results 1 to 4 of 4
Thread: Mixing FSEQ Sources To Play On FPP/Pi
    Southern California
    938
    Question Mixing FSEQ Sources To Play On FPP/Pi
    I currently use Vixen 3 to build and export my sequences to FPP/Pi. My intuition tells me that I could export FSEQ files from Vixen OR Xlights and have the FPP/Pi play them in whichever order I choose within the playlists. Is this a correct assumption?
    Kevin
    7,971
    Default Re: Mixing FSEQ Sources To Play On FPP/Pi
    Yes
    Feb 2017
    Ohio
    35
    I use both Vixen and Xlights on my fpps and have had no issues.
    Shawn
    4,298
    Vixen 3 and xLights both create .fseq files that conform to the FSEQ format. The FPP will play any file that conforms to the FSEQ format. You could generate an FSEQ file by hand (aka hex editor) and the FPP would play it. FYI: there are other sequencers that output FSEQ compliant files as well.
