Results 1 to 6 of 6
Thread: How to get liquid effect to be the same each time
    Aug 2013
    Surprise, Az
    572
    Default How to get liquid effect to be the same each time
    So I've been playing a little deeper with the liquid effect. One thing I've noticed is whenever you close the sequence and re-open it, the liquid effect will be different. The settings are all the same, but where the nozzle starts (when animate it checked) differs every time. For instance on a sequence I've been working on using liquid effect; I finally got it to start where I wanted it to (meaning the nozzle). But as soon as I shut down or modify the effect (moving it a little, adjust a setting, etc) the nozzle head will move to different starting location. Is there a way to start he nozzle in a certain place while still using "animate"?
    Hope this gibberish makes sense...
    Chris
    Oct 2009
    15
    Default Re: How to get liquid effect to be the same each time
    I created a ticket on this issue https://bugs.vixenlights.com/browse/VIX-2896
    I helped write that effect, so I think we should be able to accommodate your request. The initial position of the emitter/nozzle is randomized each time the effect is rendered. This was a design choice on my part. I think it should be easy to make it configurable. Thanks for using the effect and reporting the issue.
    John
    Aug 2013
    Surprise, Az
    572
    Awesome! Thanks, John!
    Oct 2009
    15
    We added a "Random Start" checkbox. If you uncheck that, two sliders will appear allowing you to configure the initial X and Y position of the emitter. This change has been incorporated into the development builds. If you want to try it out, I suggest you make a backup of your profile and your sequences. The change is NOT backwards compatible. http://www.vixenlights.com/downloads/devbuild/
    John
    Aug 2013
    Surprise, Az
    572
    That is perfect... THANK YOU!
    Aug 2013
    Surprise, Az
    572
    Wanted to let you know I've been using the Dev Build and this is exactly what I was looking for. Outstanding work!
