Results 1 to 10 of 19
Thread: Will this work to program PICS
    Dec 2017
    Manchester TN
    33
    Default Will this work to program PICS
    Will this configuration work to program the PICS for my SS24? I should have asked first, but I've already purchased it..
    https://www.ebay.com/itm/For-PICKIT-...72.m2749.l2649
    1,806
    Default Re: Will this work to program PICS
    If you are looking for experience with that particular device, none. If you are looking for some confidence that you are picking the right thing, you did good! It should work for both older and newer chips used in our hobby controllers including the ss24.
    Dec 2017
    Manchester TN
    33
    Thanks Mike, exactly what I needed to know.. lol
    I wasn't sure if I had bought the correct item. It comes with no instructions, so I'm doing research now on how to use it, especially how to use the ZIF adapter...
    Clarksville, TN
    309
    Looks like the same one I use, without issue.
    -Tony
    Quote Originally Posted by Topcat View Post
    Tony
    Live since 2007
    Putting the Yule back into Yuletide
    Dec 2017
    Manchester TN
    33
    Quote Originally Posted by ChiefWarrant View Post
    -Tony
    Thanks, I'll probably be back with questions if I can't figure it out...
    4,931
    It should work. However, that is not the official PICKit from Microhip. That is a knockoff and YMMV
    Dec 2017
    Manchester TN
    33
    Yes, thanks. No luck so far, but I'm sure it's just my ignorance.. I'll eventually figure it out.
    1,584
    Back of the ZIFF socket will give you the jumper setting for the different PICs mostly based on the # of pins. For a 16f688 (14Pin) you will see a line about 2/3 of the way down the ZIFF socket (line 20?) that is where you need to place the PIC, Pin1 (and 14) should be @ or just below that line.
    You also need to have the Pickit3 software on your PC
    Clarksville, TN
    309
    Topcat,
    If you don't have an answer by the end of the day, I will post a picture of what mine is set up as. In that ziff socket the PIC does not actually sit all the way to the top or bottom (like Ruppro said). I ended up marking pin #1 on mine with a sharpie so I know where they need to sit.
    Tony
    Tony
    Live since 2007
    Dec 2017
    Manchester TN
    33
    Thanks all, I've been reading and watching videos.. I have the PickIT 3 software on my computer but the PIC16F688 doesn't show up as a selection. I'll do more trials tonight when I get home. I'll check the ZIF socket circuit board for the location info, (i Didn't know about that) Also probably re-install the software.
    ChiefWarrant: Any reference photos would be helpful, thanks. I'll post progress as it happens.. LOL
    Thanks again to all!
