Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Buck converter question
    4,298
    Default Re: Buck converter question
    I tried 4 more strings and all lights work as supposed to colors are correct no pink pixels.
    Maybe a bad pixel in that one string?
    Yes most likely an LED that was not working as expected.
    Nov 2018
    Houston, Texas
    1,470
    So far these things are working great I ran 100 pixels 50percent brightness all white for few hours 28í from esp to the first pixel and another foot or two from psu to espixel no issues at all and no power injection needed and never even got warm .
    Had issues with Flickering when I installed on the out voltage of the esp and had to change the esp set up from 12 to 5 volts and reinstalled between 12 volt psu and espixel and works perfectly.
    Ordered from China at about 3 bucks each. And these are sealed units .
    Just an FYI if anyone is interested.
    Nov 2018
    Houston, Texas
    1,470
