Thread: DIY addressable lanterns
    Jan 2018
    Houston, Texas
    33
    Lightbulb DIY addressable lanterns
    Hello,
    I picked up 12 of these Christmas lanterns on clearance at a local hardware store. My original plan was to gut them and install 3 watt rgb LEDs (I have built drivers for them) and run them off of a dumb pixel controller. I have now decided to make each a component in a set of custom props that use addressable pixels.
    Is there a ws2811 solution for custom applications like this? Possibly something I could just add to the drivers that I have made? I'm aware of the Adafruit Pixies but they are too expensive and not practical for this application.
    Apr 2014
    Troy, MI
    133
    Default Re: DIY addressable lanterns
    What about the Adafruit NeoPixel Jewel at $8. There is a knockoff on Amazon, DIYmall 7 Bits 7 X WS2812 for $6. Not as much power but should light the lanterns just fine. I bought the knockoff but I have not used them yet. BTW, they are about the size of a quarter.
    Jan 2018
    Houston, Texas
    33
    I looked at these as well. There's a version that has several in a circle that I may consider if I can't make the 3 watt lights work. I want them to be unexpectedly bright at certain times in the sequence.
    Nov 2009
    Brisbane - Australia
    957
    I've used 12V WS2811 based LED modules for a couple of retrofit projects and they work well. Quite bright too. I got mine from Ray Wu.
    www.da-share.com
    4,065
    I have ten ws2811 bullet nodes hanging in each of mine.
