Results 1 to 10 of 28
Thread: First Mega Tree Questions
    Dec 2017
    Santa Claus, IN
    48
    Default First Mega Tree Questions
    I am planning out my first mega tree for next year and have some questions. I plan on going with a 180 16 strand 50 node tree. I will using the pixel mounting strips at 2 spacing. I will also be using the Boscoyo 32 topper(8.75 diameter) with a 6 diameter base(I am unsure what I will use for this but bent EMT seeks popular?). The spot where the tree will go is not level so I need to figure out how to suspend it a bit, ideas on this? My other question is what pole should I go with? I think Im going with the portable hole but will I need to go with a full blown ASAP pole or will I be okay just using a single 1-1/2 rigid electrical conduit that is 10 long?
    My last question is how is everyone mounting stars on top of their tree? Is that something else I need to take into consideration?
    Kimberly, WI
    183
    Default Re: First Mega Tree Questions
    I use 2 1/2 EMT conduit.my tree is 20 high. My base is treated deck boards in an X. I use cable guy wires to hold it up 3 half way up and three on at the top. 6 screw-in ground stakes from Home Depot to attach the guy wires to. My ground is not level either. I use cut pieces of 2x4s to level it.its solid as a rock.
    Dec 2017
    Santa Claus, IN
    48
    Are your strips attached directly to the ground on the bottom? Or is that what used 2-1/2” EMT for?
    Folsom, CA, USA
    2,113
    Quote Originally Posted by pmkoch View Post
    ...........will I be okay just using a single 1-1/2” rigid electrical conduit that is 10’ long?
    You are fine with 1-1/2 EMT for the first 10 feet, but 50 pixels at 2” is more like 14-15 feet. Similar to you, I did a 200 degree, 20 strand, 50 pixel at 2” spacing. I used 1-1/2, then inserted a piece of 1-1/4 into the 1-1/2 then set the length. Drilled and added 2 sheet metal screws to hold the length.
    Mine is free standing using 1/2 ent to build legs and braces. 8-90 bends for the feet. I did 8’ diameter
    Straps are attached with bungees to 8’ ring like base.
    In Lights Therapy
    Dec 2017
    Santa Claus, IN
    48
    After more digging it seems like going with the Holiday Coro QuickTree topper(QT8) with a 10’ 1-3/8” top fence rail in the portable hole would be quick and easy, thoughts?
    Dec 2017
    Santa Claus, IN
    48
    Wouldn't 50 pixels at 2” be like 8’ minus the angle?
    107
    Handy dandy calculator
    https://www.lightshowhub.com/tools/mega-tree-calculator
    Dec 2017
    Santa Claus, IN
    48
    Quote Originally Posted by neonexpresso View Post
    How do I get it to calculate the length of the pole? I have played around with that but I wasn’t able to get it to suggest sizes for anything. I just had to manually put my lengths in for everything.
    Nov 2014
    Close to Hillsboro, OR
    498
    I tried using that link and finally just did what looked right for me. As a reference for you, I use 50-pixel strings mounted into Boscoyo strips, 24 total, for a 360 degree tree. The pixels are spaced 2" apart and I found that 1 EMT pole measuring 10' in height was enough to mount the strings, the topper and the star -- each strip is just over 8' long. I went with a 30" radius for the pixels - a little narrower than I did last year to help keep the strips closer together. The pole sits on a wooden circle that just sits on the grass (there is a metal flange I screwed into the wooden circle to keep the pole from moving around) and I have the Boscoyo mega tree kit holding it up (meaning not only did I get the topper, but I also have 3 guy wires mounted about 4' up the pole and staked into the ground). Where I live in Oregon there's not much wind so I don't have to worry about my tree blowing over...at least, not yet. Strips are held down at the bottom using simple tent stakes - I also deal with an uneven front yard but am able to compensate using the stakes. I think my calculations came up with something like 7 3/4" spacing at the bottom between strips - there are 2 at the back that are a little wider than that, but since they are at the back, no one can see them and I have slightly easier access to the controller box if I need it. Next year I plan on getting an actual base made of metal tubing so I can have everything placed and spaced perfectly.
    Folsom, CA, USA
    2,113
    Wouldn't 50 pixels at 2 be like 8 minus the angle?
    Oops, yeah.....I did 3
    In Lights Therapy
