Results 1 to 8 of 8
Thread: 3 or more Renard plugins causing choppy results
    Long Island, NY
    7,657
    Default 3 or more Renard plugins causing choppy results
    I was intending to run 4 Renard plugins. Channels 1-48, 49-176, 177-304 and 305-368. I was noticing choppy flashing and fades and Vixen lock ups so the troubleshooting started. After pulling my hair out for over 12 hours and redoing everything in Vixen I have narrowed my issue down to 3 or more Renard plugins. I have tried this across 2 different computers and reworking all my connections, cables, board configurations and com port setups. If I use 2 Renard plugins with up to 304 channels everything runs smooth. The F8 button is a little laggy but the lights flash properly. If I run 304 channels with 3 plugins or more then the F8 button does not work and Vixen locks up.
    My only solution I can think of is to keep my plugins down to 2. This would cause me to have to put 256 channels on one plugin and the remained on another. I would have to connect 2-Ren24s inline with a Ren64, something I have not had to do to date.
    Is anyone else experiencing anything like this?
    I get the same results with Vixen 2.4.1, 2.5.0 and 2.9.0 across 2 different computers. The pcs were a 2.4ghz XP Pro with 768 ram and a 2.1ghz XP Home with 2gb ram.
    Colorado Springs
    3,712
    Default Re: 3 or more Renard plugins causing choppy results
    Brian, I was having a similar problem. When I would use 3 renard plugins, Vixen would often start freezing up while I was sequencing. I spent a lot of time working with KC on it over several days, and he finally sent me a new renard DLL file that seems to have fixed it. I may loose one blink or flash now and again, but for the most part it works fine.
    Long Island, NY
    7,657
    Any chance you can send the dll over here?
    Spencer Iowa
    1,236
    Brian do you have "keep port open" checked.
    I tried unchecking this due to the 2.5 hour freeze issue.
    When unchecked, crap more accurately describes it than choppy.
    Running 450 channels on 4 serial ports.
    Joel
    Long Island, NY
    7,657
    I unchecked "Hold port open". I got a dll from rstehle and am going to play with that. I spoke to KC today and he has some stuff he is going to send me tonight to play with as well. In the mean time I was able to get my hands on an older instal, pre 2.0.5.1 release and it seems to be running fine. I spent all day working on things and finally the show is running at about 90%. I hope this stops the emails and late night knocks at the door asking when the lights are going to be on. I had no idea the impact my display has on the community.
    Charlotte, NC
    824
    Brian / KC - Please send me the files as well - I have 392 channels spread out over 4 ports, and I've been having issues as well - I go live on the 5th at 6:00, so anything you have - I'll try right away!!!
    Camp Hill Pa.
    326
    I had issues using 3 com ports. Tried using just 2 but went over the 143 channels per com port and ran just fine with the exception on the ren 64 i have 2 ssrs that lag .05-.10 behind but i just moved the channels ahead to compensate the lag and now everything is fine. 2 sets of green lights half out but im the only one that notices the 2 out of 600+ total sets.im running 232 and using a ren 64 and 11 ren 24s and been running all week and was testing for a full week prior with no issues using the 2 com ports for that many channels. I do have to restart the laptop once each day but amazingly its been like a vacation around here since i turned on.
    Jacksonville, FL
    480
    Have you tried minimizing vixen while playing back. I have an old 333MHz that I use to play my show (Write them on my laptop) and since it is so slow I have freezing problem. When minimized the graphics don't update so it plays without any hitches. I know I could upgrade the machine but why? It's just sending serial data.
