Page 6 of 6 FirstFirst ... 456
Results 51 to 60 of 60
Thread: 5v pixel power inject
  1. #51
    Nov 2018
    Houston, Texas
    816
    Default Re: 5v pixel power inject
    Anyone have any tips on power injection on strings with no injection wires ? Or is it just splice and solder
  2. #52
    Kansas City Missouri
    2,358
    There should be wires from the last pixel. Use those.
  3. #53
    Nov 2018
    Houston, Texas
    816
    Ordered from Diy led express and all strings have no extra wires for injection so didnít know if there was a easy way to add or not
  4. #54
    2,358
    You have to use the negative and positive on the last wire out or order some tees from DIYledexpress. If their connectors aren't wired the same you will need to change the plug.
  5. #55
    2,358
    If you have connectors that will fit the ones that are on the pixels just connect to the negative and positive and not the data.
  6. #56
    Nov 2018
    Houston, Texas
    816
    Iíll check on tees thanks
  7. #57
    2,358
    You only need the tees if you intend on running another string. If not then you need a connector so you can add power. You have a choice. If not running another string then just cut off the connector and only connect the power. If running another string you will need a tee.
  8. #58
    Nov 2018
    Houston, Texas
    816
    Great thank you very helpful
  9. #59
    Jan 2010
    Melbourne, FL
    592
    How many pixels are on that string? I think what pmiller is referring to is that, many folks (myself included) would just inject the power at the very last pixel and limit the total string length to 100 pixels. If you are going to do 150 pixels per string (three x 50 pixels) as you stated earlier, then you need to have tees OR come up with some other approach. The majority of our display is done with 100 pixels per output on a controller and we send data+power to pixel 1 and then ONLY power to pixel 100. Wherever we go higher than that on the controller output (our window panel matrix units for example have 288 pixels per output), then we use tees to inject the power into the various points along the string.
  10. #60
    Nov 2018
    Houston, Texas
    816
    Quote Originally Posted by nutz4lights View Post
    Thanks I was running these on roof line edge 150 on garage edge and 169 on main house edge . My problem is everytime I order pixels from a different vender I get different injection points or none at all . The other ones from ray wu only have one injection at the beginning of each string . The ones from rextin have injection on both ends of string makes things a pain .
