Results 1 to 6 of 6
Thread: testing Wiznets
    Ontario, Canada
    2,187
    Default testing Wiznets
    I appear to have 3 dead Wiznets or 3 dead e682's or both.
    How do I go about testing the Wiznet 820io's independently from the e682's?
    I'm reluctant at this point to put a suspect Wiznet on my last working spare e682, or putting a good Wiznet on a suspect e682
    Cheers!
    Steve
    Learn 1 new thing everyday.
    "AURBO" -- Aurora Borealis
    My weather today
    6,886
    Default Re: testing Wiznets
    The odds of either are very slim . Were these kits you built yourself ? What voltage are you applying ?
    Are you using a newer revision that requires a chip select jumper for the eprom type ?
    Jan 2011
    Warren, NJ
    1,750
    More likely a networking error or bad data stored in the eprom. Go back to basics and do a manual ip address override. also reboot whatever computer you are using to access the device to make sure the wrong routing data is not in the pc or tablet, my tablet sometimes loses connection and a reboot allows me to find the e681 again. Once you find the device use the system commands 10, 20 , 30 to purge the eproms.
    Do the leds ever light up on the module? just making sure it is not a bad cat5 cable.
    Ontario, Canada
    2,187
    Built them myself in 2016
    12vdc, same psu's I've always used
    I'll check jumpers
    Cheers!
    Steve
    My weather today
    Ontario, Canada
    2,187
    Quote Originally Posted by jklingert View Post
    Both leds light up, then flash repeatedly in unison at about a 1sec interval
    I'll try commands 10 20 30 if I can access the units
    Cheers!
    Steve
    My weather today
    Tremonton Utah
    111
    Check under the wiz module. is there any sign of corrosion etc? Usually the blinking indicates a failure from the wiz. I noticed these diagnostic LEDs (with no cable plugged in) when making my custom boards with the w5500 chip. One wiznet forum member described the same issue with blinking LED's was due to a crystal issue. My issues were due to the chip not being soldered correctly.
