Results 1 to 4 of 4
Thread: How to set different size of pixel strings using Teensy 3.2 and OCTOWS2811
    Nov 2017
    48
    Default How to set different size of pixel strings using Teensy 3.2 and OCTOWS2811
    Two years ago I setup my first Pixel tree using Teensy 3.2 and OCTWS2811 controlled using Vixen and with a lot of help from this forum which worked really great. Although would have been happy if I could have created more sequences. Probably I lack creativity and composing skills.
    I am trying to use the existing OCTOWS and Teensy setup to add more pixel strings for arches and other custom designs. But I see the code where its set LEDS per strip as 2100 (14 strings of 50 pixel each * 3) for my pixel tree.
    Now I would like to add 25 pixel string for 1 prop and 75 pixel string for another prop but not sure how to set different varying sizes for controlling all 3 strips differently in the code.
    Could you suggest how this can be accomplished.
    1,713
    Default Re: How to set different size of pixel strings using Teensy 3.2 and OCTOWS2811
    Post your code or a link to it. but it is probably just hard-coding an "if" in the display lights section.
    Nov 2017
    48
    Tremonton Utah
    111
    The way I work around it is I allocate universe per port. If I allocate 1 universe then I know I can put no more than one universe of pixels per port. If say I have a string that I need 4 universes the I setup the code to handle 680 pixels worth of data per port. When I map pixels I keep in mind that each port is a 4 universe port. I use them or loose them. Port 1 is 1-4 universe, port two is 5-8 and so on. In this DIY idustry universes are expendable. May not be a solution for some lighting desks that have a limited amount of universes but for xlights or vixen and alike there is no need to be frugal.
    crees
