Results 1 to 9 of 9
Thread: Strange issue when using export Wizard
    Jul 2014
    Missouri
    141
    Default Strange issue when using export Wizard
    90% of my display is pixels but I still have a few non pixel items including a 24 string LED tree running off of an arduino and relays with an ethershield and e.131 sketch. I finally got around to getting it in the display tonight and noticed that every song but two had around 10 strings that would come on and stay on during each song. When I ran directly from Vixen the songs were fine. I ran the fpp master in test mode and they were fine. I finally just now figured out that all of the songs that were done in the export wizard are having the problem. My daughter sent me an updated song that I put in during the display and it was just fine because I did an export from the editor itself and then copied it over to the fpp master. The other two songs that were fine were also exported from the editor.
    I double checked my settings in the export wizard and they are the same as what i use when exporting from the editor except the wizard sends the files directly to the fpp master. I know the workaround for it now, but wanted to report in case others were experiencing the issue. I am going to test the wizard again tomorrow to see if the same thing happens.
    Folsom, CA, USA
    2,245
    Default Re: Strange issue when using export Wizard
    The export wizard places the file where you told it to save it. My places the fseq files in the Vixen/{profile name]/Export/sequence directory
    C:\Users\xxx\Documents\Vixen 3\Christmas 2019\Export\sequences
    In Lights Therapy
    Jul 2014
    Missouri
    141
    So, I did another export using the wizard this morning to check and all the sequences were fine. I remember yesterday before I exported that I had the tree on a twinkle in effect preview just to check to make sure that the strings were working. It was the only controller that I had active in vixen also since I use FPP for my display. As I was in the yard I noticed I forgot to shut it off. Didn't think anything about it. That is what caused the problem using the export wizard. I had that tree going in preview in a test sequence while I hit the export wizard. For whatever reason it took a snapshot of what was going on at that time and included it in every sequence that I batch exported through the export wizard.
    Southern California
    1,184
    can you post the Arduino sketch you speak of? Or a link of where to find it??
    Kevin
    Kevin
    Maryville, Illinois
    1,929
    There were some fixes to how the output folder validates and gets set that are in the current development release. It takes a certain combination of options to get it to misbehave. Are you exporting in legacy FPP, or FPP 2.6+? You might give the development build a try to see if it solves your issue.
    Jul 2014
    Missouri
    141
    Kevin
    Here ya go. Its not my sketch but I have four arduinos running a total of 96 SSRs using it.
    Code:
    Original code created January 4th, 2014 by Claude Heintz http://lx.claudeheintzdesign.com/lxa..._sketches.html
    modified by: Jared Alexander
    This code is in the public domain.
    sACN E 1.31 is a public standard published by the PLASA technical standards program
    http://tsp.plasa.org/tsp/documents/published_docs.php
    Requires Arduino Ethernet Shield. Modifed to use the lastest version of Ethernet library included in Arduino 1.6.1. No need to install other libraries.
    Receives E1.31 data (SACN) and ArtNet data for control of relays. This sketch is designed for use with SainSmart Relay boards.
    You can only send the Arduino one protocol (E1.31 or ArtNet) at a time.
    This sketch also includes a power on self test function to make sure everything is hooked up properly.
    #include <SPI.h>    //Standard Library
    #include <Ethernet.h> //Standard Library
    #include <EthernetUdp.h> //Standard Library
    /*  set the desired subnet and universe (first universe is 0)
        sACN starts with universe 1 so subtract 1 from sACN universe
        to get DMX_UNIVERSE.                                           */
    #define ARTNET_SUBNET 0 //defualt subnet is 0. Should not need to be changed.
    #define ARTNET_UNIVERSE 0 //first universe being used
    #define E131_SUBNET 0 //defualt subnet is 0. Should not need to be changed.
    #define ETHERNET_BUFFER_MAX 640
    #define ARTNET_ARTDMX 0x5000
    #define ARTNET_ARTPOLL 0x2000
    #define ARTNET_PORT 0x1936 //standard port
    #define ARTNET_START_ADDRESS 18 //Byte 18 in the packet contains channel 1 values.
    #define E131_PORT 5568 //standard port
    #define E131_START_ADDRESS 126 //Byte 126 in the packet contains channel 1 values. Offset is set to one prior.
    #define STATUS_LED 13 //shows us when we are receiving data
    #define SDCARD_CONTROL 4 //set pin 4 to high to disable SD card interface on WiFi shield
    #define NUM_RELAYS 8 //total number of relays used
    int channel; //channel increment
    //Relay Pins array
    int Relay[] = {22, 23, 24, 25, 26, 27, 28, 29};
    //Timer Setup
    volatile byte currentcounter = 0; //counter for data reception
    byte previouscounter = 0; //counter for data reception
    unsigned long currentDelay = 0; //current time value for ArtNet and E1.31 reception
    //Ethernet Configuration
    byte mac[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
    IPAddress ip(192, 168, 1, 120);  //IP address of ethernet shield
    // buffer to hold E1.31 and Artnet data
    unsigned char packetBuffer[ETHERNET_BUFFER_MAX];
    // An EthernetUDP instance to let us send and receive packets over UDP
    // aUDP creates a socket for an Art-Net port
    // suUDP creates a socket for sACN that is unicast to the ip address
    EthernetUDP aUDP;
    EthernetUDP suUDP;
    void setup()
      pinMode(STATUS_LED, OUTPUT); //Initialize status LED
      pinMode(SDCARD_CONTROL, OUTPUT); //Initialize Pin 4
      digitalWrite(SDCARD_CONTROL, HIGH); //Set pin 4 to high since we are not using the SD Card interface
      for(int a = 0; a < NUM_RELAYS; a++) //loop to initialize relay control pins
       pinMode(Relay[a], OUTPUT); //initialize relay output pins
       digitalWrite(Relay[a], HIGH); //set pins to high for off
      Ethernet.begin(mac,ip);  //Initialize Ethernet shield
      aUDP.begin(ARTNET_PORT); //Open Artnet Port
      suUDP.begin(E131_PORT); //Open E1.31 Port
      Serial.begin(9600); //Serial for debugging
      POST(); //Run Power On Self Test Function
      Serial.println("Setup Complete"); //print complete
    /* artDMXReceived checks the universe and subnet then
       outputs the data to the relays */
    void artDMXReceived(unsigned char* pbuff)
      if ( (pbuff[14] & 0xF) == ARTNET_UNIVERSE )
        if ( (pbuff[14] >> 8) == ARTNET_SUBNET )
          channel = 0; //reset channel offset to 0 each time through loop
          //loop turns relay on/off based on channel value starting at Artnet start address
          for(int b = 0; b < NUM_RELAYS; b++)
           if(pbuff[ARTNET_START_ADDRESS + channel] > 127) //if channel value is greater then 127
           digitalWrite(Relay[b], LOW); //turn relay on
          else
           digitalWrite(Relay[b], HIGH); //else turn it off
          channel++; //increase channel offset by 1 each time through for loop
    } //end artDMXReceived
    /*  artNetOpCode checks to see that the packet is actually Art-Net
        and returns the opcode telling what kind of Art-Net message it is.  */
    int artNetOpCode(unsigned char* pbuff)
      String test = String((char*)pbuff);
      if ( test.equals("Art-Net") )
        if ( pbuff[11] >= 14 )
        {            //protocol version [10] hi byte [11] lo byte
          return pbuff[9] *256 + pbuff[8];  //opcode lo byte first
      return 0;
    /* sacnDMXReceived checks the universe and subnet then
       outputs the data to relays  */
    void sacnDMXReceived(unsigned char* pbuff, int count)
        if ( pbuff[113] == E131_SUBNET )
          int addressOffset = 125; //first 125 bytes of packet are header information
          if ( pbuff[addressOffset] == 0 ) //start code must be 0
           //loop turns relay on/off based on channel value starting at E1.31 start address
          for(int c = 0; c < NUM_RELAYS; c++)
           if(pbuff[E131_START_ADDRESS + channel] > 127) //if channel value is greater then 127
           digitalWrite(Relay[c], LOW); //turn relay on
          else
           digitalWrite(Relay[c], HIGH); //turn relay off
          channel++; //increment channel offset by 1
        } //end sacnDMXReceived
    //checks to see if packet is E1.31 data
    int checkACNHeaders(unsigned char* messagein, int messagelength)
      if ( messagein[1] == 0x10 && messagein[4] == 0x41 && messagein[12] == 0x37)
          int addresscount = messagein[123] * 256 + messagein[124]; // number of values plus start code
          return addresscount -1; //Return how many values are in the packet.
      return 0;
      The main loop checks for and reads packets from the two UDP ethernet
      socket connections.  When a packet is recieved, it is checked to see if
      it is valid and then one of the DMXReceived functions is called, sending
      the DMX values to the output. There also is a timer to run a standby
      program if no data is received for 30 seconds.
    void loop()
      if(currentcounter != previouscounter) //has the value changed?
        currentDelay = millis(); //store the time since the value has increased
        previouscounter = currentcounter; //set the previous value equal to the current value
      if(millis() - currentDelay > 30000) //is the time since the value changed greater than 30 seconds?
       digitalWrite(STATUS_LED, LOW); //turn LED off. Not receiving E1.31 or ArtNet.
      // first check to see if a packet is available on the Art-Net port
      int packetSize = aUDP.parsePacket();
      if( packetSize )
        aUDP.read(packetBuffer, ETHERNET_BUFFER_MAX);
        /* after reading the packet into the buffer, check to make sure
           that it is an Art-Net packet and retrieve the opcode that
           tells what kind of message it is                         */
        int opcode = artNetOpCode(packetBuffer);
        if ( opcode == ARTNET_ARTDMX )
          Serial.println("ArtNet Packet Received");
          artDMXReceived(packetBuffer);
          currentcounter++;  //increase counter by 1 each time through
          digitalWrite(STATUS_LED, HIGH); //turn status LED on
        else
          /* then, if still no packet, check to see if a packet
             is available on the sACN unicastcast port         */
           packetSize = suUDP.parsePacket();
        if( packetSize )
          suUDP.read(packetBuffer, ETHERNET_BUFFER_MAX);
           that it is a valid sACN packet.*/
          int count = checkACNHeaders(packetBuffer, packetSize);
          if ( count )
            Serial.println("E131 Packet Received");
            sacnDMXReceived(packetBuffer, count);
    } //End loop
    //Power on self test function to make sure everything is connected properly.
    void POST()
      digitalWrite(Relay[0], LOW);
      delay(1000);
      digitalWrite(Relay[0], HIGH);
      digitalWrite(Relay[1], LOW);
      delay(1000);
      digitalWrite(Relay[1], HIGH);
      digitalWrite(Relay[2], LOW);
      delay(1000);
      digitalWrite(Relay[2], HIGH);
      digitalWrite(Relay[3], LOW);
      delay(1000);
      digitalWrite(Relay[3], HIGH);
      digitalWrite(Relay[4], LOW);
      delay(1000);
      digitalWrite(Relay[4], HIGH);
      digitalWrite(Relay[5], LOW);
      delay(1000);
      digitalWrite(Relay[5], HIGH);
      digitalWrite(Relay[6], LOW);
      delay(1000);
      digitalWrite(Relay[6], HIGH);
      digitalWrite(Relay[7], LOW);
      delay(1000);
      digitalWrite(Relay[7], HIGH);
      Serial.println("POST Complete");
    Jul 2014
    Missouri
    141
    I am on Development build #934 right now. Here are my export setting on the wizard.
    I will just know not to have effect preview going while I do the Export.
    Maryville, Illinois
    1,929
    Quote Originally Posted by jwamsley07 View Post
    Yes, you should not be trying to sequence or using the effect preview during the export. The export turns off anything running when it starts, but if you start it up in the middle, then that can definitely cause issues.
    Southern California
    1,184
    Thanks for the sketch. Another user was asking me for an Ethernet sketch and i want to test one out for myself. Thanks again.
    Kevin
