Correct. The scheduler requires something in the sequential tab. It should work with any kind of item. Even a pause. So if you do that, it will play the sequence in the startup section once. And then it will loop on whatever item is in the sequential section over and over until the scheduled time window expires. Then it will finish out whatever last task it's doing and jump to the shutdown section, which can be empty if you like.
