Results 1 to 10 of 14
Thread: Wanted: Vixen 2.0 software
    Ballarat, Australia
    19
    Default Wanted: Vixen 2.0 software
    Hi Guys, I'm looking for the vixen install files for 2.0. Having issues with outputs to the lights with 2.0.9+ and wanting to try the 2 version that I used to use. But can't find the install files.
    Stephen
    1,250
    Default Re: Wanted: Vixen 2.0 software
    I doubt you will find 2.0 but the 2.1.1.0 version was solid when I used it 5 years ago. Go to VixenLights, then downloads and you find a link to the 2.x version.
    Ballarat, Australia
    19
    That was the first thing I tried. Have even done a fresh install of windows, vix and only copied the sequence files over. After a while vixen will just stop outputting to the lights, but is still playing the sequence. Sometimes vixen will even crash.
    Playing each sequence one after the other, having loaded them into vixen works and just switching sequence windows. But not if I use a program and schedule a event time.
    Richmond, TX (Pecan Grove)
    274
    this seems like some odd behavior, i'd be surprised if it's related to the version of Vixen, as 2.1.1.0 is pretty solid. Are you running same sequence files that you would've run in the past with vix 2.0 - ie, have you created newer sequences, maybe larger (for example adding lots of channels for pixels)? Are you possibly running into memory issues (I've seen program scheduler crash/stop when I tried to incorporate some very large sequences that ran OK by themselves). If you're having issues with output to the lights, perhaps check the output plugins (you don't mention what you're using - renard, dmx, e1.31, etc), check the physical connections, is it possible something is happening at the controller side. Sorry I can't help with 2.0 - good luck.
    Ontario, Canada
    2,140
    Vixen Legacy 2.x can be downloaded here
    Cheers!
    Steve
    Learn 1 new thing everyday.
    "AURBO" -- Aurora Borealis
    My weather today
    Mooresville, NC
    7,593
    I have a copy of all of them, just let me know which one you want.
    Dickson City, PA
    509
    I have Vixen back to .91, boy has it changed!!
    Zaker
    1 - Ren 64
    4 - Ren 24
    1 - Ren48LSD
    2 - E681
    LOTS OF LIGHTS!!
    [URL]http://lights.quietwebhosting.com[/URL]
    Ballarat, Australia
    19
    Quote Originally Posted by EMKLLK View Post
    The output being used is the Olsen595 via lpt port, and I can play a single sequence for ever with no issues what so ever. It's when put into a program to schedule the start time that after a while of playing (five-ten minutes) the output to the 595 just stops, and I have to kill vixen to restart. The sequences are from 2007, and haven't changed since then. Although there are a lot of them in the sequence directory. I first noticed the issue when the machine had 512mb of ram (used to run great for the 2007-2009 years), then upped to 1gb, then 2 and now 3. The machine is a all-in-one with XP installed. (I had a long break due to life issues, and only came back to doing lights last year. Hence why all the old gear. I am moving to pixels, but it's going to take a while, and the current gear works except for this issue with vixen.
    Ballarat, Australia
    19
    Quote Originally Posted by Aurbo99 View Post
    Vixen 2.1.1.0 is on the vixen website, but not 2.0.
    Ballarat, Australia
    19
    That would be great. I have 2.0.9.0, and that has the issue plus the recent versions. So would like to try 2.0 or any of the 2.x versions before 2.0.9.0.
    Stephen
