Results 1 to 4 of 4
Thread: New setup lots of questions
    Dec 2019
    1
    Default New setup lots of questions
    Hello all! I am very new to all this and am working on setting up my first display (piece by piece). I want to start small and simple so I am going to set up some small candy canes. My first question is all that I need this is the list I have so far and have ordered:
    1 F4V3 controller
    3 12v bullet leds
    3 boscoyo candy canes
    Xlights
    Computer
    I know I need a power supply and that's something else I need help with (I know I need 12 volts but what wattage?) But is there anything else I need for this first set up?
    Also as for cords I am not sure what to look for for the outputs on the controller board like what the name is for the port with 4 inputs so that I can make a pigtail adapter for the lights?
    Any help is appreciated! Hopefully will have all the parts soon and can start a new addiction!
    Sent from my SM-N975U using Tapatalk
    Jan 2019
    USA - Boca Raton, FL
    45
    Default Re: New setup lots of questions
    Wattage of power supply would be directly related to wattage of your bullet lights. Each 12v 12mm bullet pixel consumes 0.3W . So just multiply number of pixel to 0.3 e.g. (50 x 0.3 = 15W) then add 20% . So single string of lights needs 18W (1.5A) power supply.
    4,847
    Quote Originally Posted by EvoMoto View Post
    12V pixels are not all the same. If you have 12v pixels with built in regulators then they use (5v * 0.06a) = 0.3w * 1.2 = 0.36w (1.2 is the voltage regulator efficiency). If your 12v pixels do NOT have the built in regulators, then the correct wattage calculation is 12v * 0.06a = 0.72w / pixel
    Dec 2018
    55
    Quote Originally Posted by tendau View Post
    1 F4V3 controller
    3 12v bullet leds
    Xlights
    Computer
    Just order a 12V 350 watt PS. You'll be able to use the extra watts when you decided to grow your display.
