Thread: Pixel Mini trees - XNOR
    Sep 2008
    Baulkham Hills, NSW
    2,608
    Default Pixel Mini trees - XNOR
    A loong long time ago when I installed my Pixel Mini Spiral Trees, i used channel grouping ( pixel control was hard in Vixen 2) to hide green LED, abd then apply random to Red and blue with a relatively low suration. this gave the affect of sparkling lights on a green tree. some times I would use use a XOR paste of the green to remove some green. Them was the days.
    Out of interest, I am trying to replicate a similar affect is Vixen 3. Ideally what I want is Green trees with colour flashing lights.
    Can any one give me some pointer on this?
    [B][I]Matt[/I][/B]
    7,955
    Default Re: Pixel Mini trees - XNOR
    use a green set level on the base layer
    Add a second layer above it, set it to color change.
    Put a twinkle effect on that layer. Set the color to red.
    Add another twinkle effect to that same layer and set the color to blue.
    Sep 2008
    Baulkham Hills, NSW
    2,608
    Thanx for the reply.
    I tried your method but it didseem to work well, so tried this
    Add Colour wash, change gradent to green, lower the intensity to 25%.
    Add Meteors with motion set to Randome, Rainbow Colour type, Count set to 80.
    That gives the affect I want.
    [B][I]Matt[/I][/B]
