Results 1 to 9 of 9
Thread: config for Nodemcu with multiple strands on same pin
    Jan 2019
    4
    Default config for Nodemcu with multiple strands on same pin
    Hi, new member here with a basic question. I setup a nodemcu with a 5v WS8212B strip of 150 pixels using the following code:
    Code:
    #include <ESP8266WiFi.h>
    #include <E131.h>
    #include <Adafruit_NeoPixel.h>
    #define NUM_PIXELS 150   /* Number of pixels */
    #define UNIVERSE 1   /* Universe to listen for */
    #define CHANNEL_START 1   /* Channel to start listening at */
    #define DATA_PIN 2  /* Pixel output - GPIO 2 */
    const char ssid[] = "xxx";   /* Replace with your SSID */
    const char passphrase[] = "xxx";    /* Replace with your WPA2 passphrase */
    E131 e131;
    Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUM_PIXELS, DATA_PIN, NEO_GRB + NEO_KHZ800);
    Adafruit_NeoPixel pixels_b = Adafruit_NeoPixel(NUM_PIXELS_B, DATA_PIN_B, NEO_GRB + NEO_KHZ800);
    void setup() {
        Serial.begin(115200);
        delay(10);
        // Initial pin states
        pinMode(DATA_PIN, OUTPUT);
        digitalWrite(DATA_PIN, LOW);
        e131.begin(ssid, passphrase);   /* via Unicast on the default port */
        /* Initialize output */
        pixels.begin();
        pixels.show();
    void loop() {
        /* Parse a packet and update pixels */
        if(e131.parsePacket()) {
            if (e131.universe == 1) {
                for (int i = 0; i < NUM_PIXELS; i++) {
                    int j = i * 3 + (CHANNEL_START - 1);
                    pixels.setPixelColor(i, e131.data[j], e131.data[j+1], e131.data[j+2]);
                pixels.show();
    I added the network setup to xLights and run a successful test chase to verify all pixels light up.
    That part works great! However what I'd like to do is run 2 strips of 150 pixels each off a single port on the nodemcu, but I'm not sure what needs to be done in code on the nodemcu and xLights to support that. I tried changing the NUM_PIXELS to 300, but that didn't work out. I tried specifying another universe (2), but couldn't get the settings right to make it work. Can someone point me in the right direction?
    Doug
    6,100
    Default Re: config for Nodemcu with multiple strands on same pin
    Hi , I haven't tested this but it does compile
    Code:
    #include <E131.h>
    #define NUM_PIXELS_B 150   /* Number of pixels */
    #define UNIVERSE 2   /* Universe to listen for */
    #define CHANNEL_START 451   /* Channel to start listening at */
    E131 e131;
    Adafruit_NeoPixel pixels_b = Adafruit_NeoPixel(NUM_PIXELS_B, DATA_PIN, NEO_GRB + NEO_KHZ800);
    void setup() {
        delay(10);
        pixels.begin();
        pixels.show();
        pixels_b.begin();
        pixels_b.show();
    void loop() {
                pixels.show();
            if (e131.universe == 2) {
                    int j = i * 3 + (CHANNEL_START - 451);
                    pixels_b.setPixelColor(i, e131.data[j], e131.data[j+1], e131.data[j+2]);
                pixels_b.show();
    Jan 2019
    4
    Thanks for trying, unfortunately it didn't work. It keeps flashing the first string, and doesn't light up the second string.
    6,100
    take 2 , this may need a universe count added.
    unfortunately I haven't tried to get more than one universe on a single pin.
    You could load EspixelStick firmware .
    Code:
    #include <E131.h>
    #define NUM_PIXELS 300   /* Number of pixels */
    E131 e131;
    void setup() {
        delay(10);
        pixels.begin();
        pixels.show();
    void loop() {
                pixels.show();
                pixels.show();
    6,100
    Try Multicast . I added it in your code , also a correction
    Code:
    #include <E131.h>
    E131 e131;
    void setup() {
        delay(10);
      //  e131.begin(ssid, passphrase);   /* via Unicast on the default port */
       e131.beginMulticast(ssid, passphrase, (UNIVERSE)); /* via Multicast for Universe 1 */
        pixels.begin();
        pixels.show();
        pixels_b.begin();
        pixels_b.show();
    void loop() {
                pixels.show();
                for (int i = 0; i < NUM_PIXELS_B; i++) {  // I forgot the _B
                pixels_b.show();
    Jan 2019
    4
    I was able to get the ESPixelStick firmware installed and that is working great- it sees both universes. Thank you for your help!
    Nov 2015
    33
    Were you able to find a How to? ESPixelStick firmware to NodeMCU? I can't seem to find anything on it.
    Quote Originally Posted by dhenning View Post
    4,065
    ESPixelStick code is an arduino sketch designed to run on ESP8266 based platforms. The nodeMCU devices I have seen are typically ESP8266-12 based platforms. As long as you are using an ESP8266 based platform, the ESPixelStick sketch can be compiled to work on it.
    Jan 2019
    4
    I don't remember where I found the info, but here are the steps I took. I am on a Windows 10 PC, not sure what changes are required if any for a Mac or other OS. I used the pre-compiled firmware on a stock NodeMCU V3 so I didn't have to compile anything, and it worked fine.
    1. Download the firmware from the Github page: https://github.com/forkineye/ESPixel...eases/tag/v3.0
    You only need to download the zip file (ESPixelStick_Firmware-3.0.zip), then extract to a directory.
    2. Plug in your NodeMCU with the USB cable to your PC (hold down the "Flash" button as you plug it in to put it into flash mode.)
    3. From a command prompt, run the EspFlashTool that's in the root of the unzipped directory (make sure you have java installed):
    java -jar ESPSFlashTool.jar
    4. It will open a dialog box- fill in your wifi info, hostname, etc. It should fill in the Firmware and Serial Port automatically.
    5. When you're ready, just click "Upload". It should take about a minute to flash, then check the Serial Output window to find the IP address it assigned.
    6. Open up that IP in your browser, and you should see a ESPixelStick status page. Use the Device Setup tab to configure your pixel setup.
    That's it!
