Results 1 to 7 of 7
Thread: Power Supply Equation
    Jan 2019
    Honokaa, HI
    14
    Default Power Supply Equation
    Aloha,
    I have been looking (and failing) for the equations to figure out how many pixels can be powered per power supply. I see people saying it's like 530 pixels for a 350W PS, but I want to understand where that number comes from. Does it change based on brightness? I'm sure this has been asked before so sorry that I couldn't find it.
    Also I realize this is really general with no specifics and that's because I'm looking for the generalities. I plan on running 5V and 12V in my designs in the future.
    Do we need to account for current draw from a controller board as well or are they generally negligible.
    If you really want my specifics I have a single 12V 350W PS, 350 12V bullets, 18ga wire.
    Mahalo,
    Sam
    Dec 2017
    Canton, OH
    4
    Default Re: Power Supply Equation
    The general rule of thumb is 0.3 watts per pixel at full white brightness... multiply that by number of pixels and voltage to get the required watts at max load... and then factor in about 20% more for overhead and controller power...
    There are other factors that apply.. but that should get you in the ballpark/a basic understanding of it
    Sent from my SM-G975U using Tapatalk
    CantonSouthChristmas
    84
    Yes power does correlate to brightness. The controller itself draws minimal power if not powering pixels through it. As for 350 pixels the power supply should do that. You’re getting close if 12v. But are all 350 hooked together in a string or multiple strings equaling 350. That will make a difference on how you approach it.
    Sep 2007
    Valley Center, Ks
    410
    From a purely electrical design standpoint. You would calculate the power supply capacity as follows:
    Current (amps) = Power (watts) / Voltage
    350/12 = 29.17 amps
    So assuming you have typical pixels like DIYLEDExpress sells then each pixel will draw 50mA at full brightness and white color. 50mA = 0.05A
    So for 10% spare capacity
    29.17*0.9/0.05 = 525 pixels
    Find out the current draw of your pixels and you can make these calculations for your installation.
    Lot of people will go for 20% spare. I typically keep my pixels at 70-80% brightness so that gives more safety margin.
    Dave-1200Px-20KLts
    3,892
    I use 20% and I use 0.06a / pixel
    West Bloomfield, MI
    660
    As a 5 V pixel user with limited power availability, note that with a 350 watt power supply, you can run more than twice as many pixels. Owning an old home with limited outside outlets made this a perfect option for me. My whole show runs from one 20 Amp outlet. 2400 watts available, six 300 watt power supplies running pixels at 50% brightness. Plenty of safety factor even at full brightness.
    Ed
    Happily retired
    Jan 2019
    Honokaa, HI
    14
    Aloha,
    Thanks all. I guess I'd seen the equation for fuses when I was researching power injection but didn't really push that knowledge into the next realm.
    Mahalo,
    Sam
