Results 1 to 4 of 4
Thread: Having Trouble getting P5 Matrix Working
    Jan 2010
    507
    Default Having Trouble getting P5 Matrix Working
    BBB with DIYLEDEXPRESS Scroller
    5x3 P5 Panels
    A solid fill in test mode produces bars roughly 8 pixels wide
    Bridge mode and xLights produces the same bars.
    Help.
    Folsom, CA, USA
    2,191
    Default Re: Having Trouble getting P5 Matrix Working
    All outputs must be equal. Use 5 outputs with 3 panels each or 3 outputs with 5 panels each
    Edit: you do not need to use all outputs.
    In Lights Therapy
    Jan 2010
    507
    Didn't know that....Thanks. Will give it a try.
    Between that and a bad ribbon cable it's getting closer.
    Nov 2014
    Close to Hillsboro, OR
    545
    Just throwing this out there...
    ...I'm running a 20-panel P5 matrix, 5Hx4W, and I use all 8 outputs. Four outputs going to 2 panels each, and four outputs going to 3 panels each. It's working fine for me with this setup. I believe Dan Kulp said something earlier this year about trying to use as many outputs with fewer runs as possible, so I would utilize the 5 outputs with 3 panels each setup that Mr. Grumpy recommended.
