Most likely the V- or Data line from the ESP to the first pixel has a bad connection.
Good evening.
I have a setup of 3 esp in a single large box. With a single power supply serving all 3.
These are controlling lines of pixel runs.
On one of them I'm getting random flickering on the data line making the pixels flash. Not all at once but irregularly.
Has anyone else had this issue before. I'm going to try moving that esp to its own box and a seperate supply.
If I move the supply pigtail away from another run of pixels. The flickering decreases but is still there.
Many thanks
80+ plus channels
2 x 32 channel custom build tlc5940 dimmable DC controllers.
1 ren 48 LSD v3c
All rgb strips and 1 custom made face.
Hi. Thanks for that.
I've changed the cable.
The first pixel aswell as the pigtail ends.
I havent tried rterminating the esp connection yet.
80+ plus channels
1 ren 48 LSD v3c
How long is the cable from the esp to the first pixel?
The run is 6mtrs long.
80+ plus channels
1 ren 48 LSD v3c
Could this be too much of a run for a 5volt.
80+ plus channels
1 ren 48 LSD v3c
