Results 1 to 10 of 15
Thread: Old sequence new problem
    Oct 2017
    44
    Default Old sequence new problem
    While testing and starting my show i have 1 element on a sequence from last year that isnt firing. It's only on this ONE sequence. It is showing up in the preview on the computer screen but not in the yard. I have tried unpatching and repatching with no change. I should also mention I am running all renard boards and a/c lights (incondecent). It is one mini tree with 2 separate colors running. I'm at a loss guys...
    Sent from my SM-N950U using Tapatalk
    Jan 2010
    494
    Default Re: Old sequence new problem
    Have you tried switching the mini tree to another Renard output to see what happens?
    Edit: I just saw it's only with one sequence so switching outputs wouldn't make a difference.
    Oct 2017
    44
    I have no free outputs. And the tree fires on other sequences. I know its weird
    Jan 2010
    494
    vixen? xlights?
    Oct 2017
    44
    I have rebooted the computer, restarted vixen, and rebooted my boards....
    Oct 2017
    44
    Vixen 3.x
    Oct 2017
    44
    Rewatching the show now and it appears to be not responding on mutiple sequences and working on others. These are all the same sequences I used last year.
    7,955
    Try the latest dev build. This sounds like it might be related to a bug we fixed a few days ago.
    Oct 2017
    44
    I will have to check it tomorrow when the show isnt running. Will I have to redo it all or will the upgrade/patch just go over the previous version?
    7,955
    Dev builds don't install over the release build. They install a 2nd copy of vixen. The release version will still be there. You should get a second vixen icon on your desktop that says development build. You can run the dev version on your existing profile and it should just work. So long as your release version is 3.6.x, there's no breaking changes in this dev build that prevent you from going back to the 3.6.x release version.
