The transmitter itself has to be able to support RDS. And those $7 transmitters do not have that capability. You would need to buy a new transmitter w/ RDS
Hello again! I have this really neat cheap $7 FM transmitter I got from eBay and it works amazing! I'd now like to add RDS to it if it is even possible. I've seen Wayne has done it with his transmitter. I am hoping I can too with this. I am using FPP and Vixen 3. I see that TinyRDS is an option in Vixen 3.
Transmitter I have:
https://www.ebay.com/itm/DSP-PLL-87-...72.m2749.l2649
The encoder I want to use:
https://pira.cz/rds/show.asp?art=micrords_encoder
Crazy Light Addict.
What about this:
https://pira.cz/rds/show.asp?art=minirds_encoder
"It's not important if you use this RDS encoder with one transistor FM bug or 1 kW transmitter."
I am confused about what this is then. If a radio has RDS what's an encoder do?
Crazy Light Addict.
Also, what are the TX, RX, and GND pins for on the eBay transmitter? What can I connect to that?
Crazy Light Addict.
http://digwdf.org/store/
The SI4713 things work "OK" for both transmitter and RDS:
https://www.amazon.com/Adafruit-Ster.../dp/B00SK8ME4Y
Little more expensive than the $7 transmitter, but it does support RDS and there are actually two different FPP plugins that work with it.
Dan Kulp
Thanks, guys for the help! :D
Crazy Light Addict.
The tx and rx pins are for the serial interface. The description mentions
7: supports serial command control
and that would be the way to send the serial commands
