Thread: First Xmas lighty thing
    Nov 2019
    4
    Default First Xmas lighty thing
    I've ordered 150 bullet pixel string, planning on building small grid to display some sequences, using espixelstick and xlights.
    Should I go with 12x12 leaving six out, or 10x15?
    Also, what spacing between pixels would be a good compromise between size and resolution?
    Thanks in advance,
    6,081
    Default Re: First Xmas lighty thing
    For resolution you will require another 2073450 bullet pixels
    10 x 15 will look better than 12 x 12 imho 1-1.5 for semi sharp image and 3" max for bold-broad image/
    If you have access to 1/2 x 1/2 wire you could experiment to find what suits you best .
    Nov 2019
    4
    Thanks for that, when the pixels arrive will mock up 10x15 and see how it looks
    Feb 2016
    Somers point nj
    427
    Quote Originally Posted by kenmc View Post
    In xlights you can design your prop before actually building it to see what it will look like. Id give that a try first.
    Nov 2019
    4
    Quote Originally Posted by Dkelly0802 View Post
    In xlights you can design your prop before actually building it to see what it will look like. I’d give that a try first.
    I've done that, but without having actual LEDs to set out to see in real life, it's hard to know if the spacing will be ok for real
