Results 1 to 4 of 4
Thread: Arduino + Pixel + Vixen issue
    Nov 2019
    2
    Default Arduino + Pixel + Vixen issue
    I have got 2 strands of 50 pixel WS2811, firstly I found I was getting green when I had red in Vixen, but I found that issue and if you haven't found it here it is:
    Code:
        // Let the FastLED library know how many pixels we will be addressing
        FastLED.addLeds<WS2811, DATA_PIN, GRB>(leds, num_leds);
        // Loop through each of the pixels and read the values for each color
        do {
          while(!Serial.available());
            leds[cnt].r = Serial.read();
            leds[cnt].g = Serial.read();
            leds[cnt++].b = Serial.read();
        while(--num_leds);
        // Tell the FastLED Library it is time to update the strip of pixels
        FastLED.show();
        // WOO HOO... We are all done and are ready to start over again!
    FastLED.addLeds<WS2811, DATA_PIN, GRB>(leds, num_leds); need to be FastLED.addLeds<WS2811, DATA_PIN, RGB>(leds, num_leds); to avoid reversing Red and Green
    The issue I can't figure out is how to get intensity to work, does anyone know this? I have noticed that the code is missing FastLed.SetBrightness(xxx); to be able to accomplish this but this means that some effects in Vixen don't work as intended. Anyone have code to take care of that?
    4,070
    Default Re: Arduino + Pixel + Vixen issue
    The lines like this: "leds[cnt].r = Serial.read();" set the intensity for each color in the tri-color LED
    Nov 2019
    2
    I believe that actually sets the red value.
    To break the line down, Leds is an array of 1 to 50 with values for R G and B. Be interested to see what Vixen actually sends down the USB pipe.
    1,205
    Vixen sends the value for r g and b. The "brightness" of red is whatever the value of r is. So 50% brightness is 128.
