Thread: Rope Light writing
    Oct 2017
    16
    Default Rope Light writing
    Hey all. I am looking to write "Merry Christmas" and hang it vertical. I was wondering what is the best way to secure it to the house? I was wanting to put it on plywood or a similar materal if I can find something that is lighter, but I'm not sure whats the best way to secure it to the house without drilling into the house and through the siding. I am not sure if they make a bracket that is strong enough to hold this weight. I was thinking using these https://www.amazon.com/Siding-No-Hol.../dp/B07YS4KW4Y but they are only rated to 18 lbs.
    Any ideas?
    1,699
    Default Re: Rope Light writing
    Each letter should not be more than 18 lbs if you are using lightweight backer (cut away as much as you can). You could stack a bunch of those clips per letter and should be fine.
    Alternately, use dual cables screwed into a roof tail in your soffit area. Secure the bottom side into a earth anchor. Or stretch a rope over the top of the building and secure it in the back yard. I suspect you might have some "slack" problems doing this but it shouldn't mess anything up too bad and you can tighten it up every couple of days.
    Oct 2017
    16
    I guess its my fault. I didnt specify and also I dont know if I am in the right forum. I'm looking to do the writing with the rope light on one big board. Not cut outs.
