Thread: Set Default Library Curve for Sequence?
    May 2015
    44
    Default Set Default Library Curve for Sequence?
    I don't use dimming curves, but the majority of my elements run at 40% intensity. It's work intensive to add new effects to the sequence (which come in with 100% intensity) and change them to 40%. Can the new sequence intensity default be changed?
    Maryville, Illinois
    1,711
    Default Re: Set Default Library Curve for Sequence?
    There is not currently a way to default the curves in the effects. You can create a library curve and drag that onto the effect instead of editing each one. If you are always dimming a prop to that, a dimming curve makes more sense in the long run.
    1,507
    You can set the dimming curve for each element in the Display Setup so any effect on the element will only be a max for what you set, 40%
    Sent from my ASUS_A009 using Tapatalk
