Results 11 to 20 of 25
Thread: Two power supplys
    441
    Default Re: Two power supplys
    Looking at your AC 3-prong connection: wouldn't be better to just have a each PSU on its own 3-prong AC connection? I guess you *could* (?) daisy-chain the AC--but that doesn't seem the best method.
    Folsom, CA, USA
    1,984
    You want to tie the DC -V of the two PSUs together, which since the -V (GND) wire for the string of pixels needs to run the entire length of the sting - they are automatically tied together. You never want to cut -V in a string because the Data is in reference to GND (-V)
    "You want to tie the DC -V of the two PSUs together" Not sure this is a good idea for all applications. I feel this is only true if you are sharing DATA with 2 power supplies. Example: if I have 2 controllers, each with their own power supply, lighting a Mega Tree with 1000 Pixel per controller, then there is no reason to tie the V- together. Even on the same element. let each (controller, PS and pixels) act as its own system.
    In Lights Therapy
    Folsom, CA, USA
    1,984
    I think daisy chaining the 120V is best practice. Assuming they are in close proximity
    In Lights Therapy
    441
    If they're in close proximity, then just get an appropriately-sized PSU so that there is only one to deal with.
    Folsom, CA, USA
    1,984
    Yes - that works, but that could create more problems. Such as replacing 2 350W power supplies with a new pricy 600W power supply. Price 2-Meanwell @ $33 ea or $66 for 2, vs a 600W for $84 - - $18 more.
    I would also be concerned of a greater potential to fry the power track on the controller with twice the amps available. Which will blow first. The Fuse of the Power Track
    In Lights Therapy
    441
    Funny--I use that same argument against using a single, large controller versus smaller ones.
    As far as "frying the power track on the controller"--that's what fuses are for.
    3,899
    As mentioned in one of the posts. There really is no reason to tie the V- on the supplies together. It does not get you anything. You DO need to run V- plus DATA together at the pixels. Even if you tie the V- at the PSU you STILL need to run the V- plus DATA at the pixels. Remember you need to run the V- plus the data AT the pixels. Should I say it one more time?
    Folsom, CA, USA
    1,984
    …...As far as "frying the power track on the controller"--that's what fuses are for.
    How fast is your fuse.....is it faster than the power track?
    Looking at a time current curve for an 20A ATO Automotive fuse, the let thru current at 0.5 seconds is 50A. What is the withstand of the Power Track on the controller board? Can it withstand 50A for 0.5 seconds, or would it be the fuse and pop first?
    Bwinter, not saying you fusing isn't correct, I'm just point out some things that are generally overlooked.
    In Lights Therapy
    Jul 2010
    Bradenton, Florida
    229
    Thank you all. I will leave the setup as is.
    John
    441
    So you're basically saying that we should all use 350W (or small) PSUs for our shows, so as "not to have too much power available to fry the power tracks" on our controllers.
    I've never seen that as a warning for any of the controllers, or ever mentioned as a concern elsewhere. I know there are many of us who have a centralized PSU that distributes power to all of our controllers/pixels--and I've never heard of this being a problem (or concern).
