Distance is not your primary consideration. There are a wide variety of quality and clarity issues that need to be looked at. I started with an FM02 class device and while the sound quality was OK, there was a bit of distortion and noise and almost no bass. I moved to an EDM and love the sound quality. I use a home made ground plane antenna mounted low to the ground with the transmitter set to its lowest settings. I get about 2 blocks before the signal fades and the fidelity at the display is great. there are other devices that work well and I am sure others will chime in shortly.
