Thread: Which type of Wire to use
    Dec 2017
    Indiana
    60
    Default Which type of Wire to use
    This will hopefully be my last question that has to do with material. Which type of wire do you guys recommend for cutting/splicing, power injection, & longer runs to supply power. I was looking at some 3 wire on Amazon but it looks like some of the wire is not very good and some is rated inwall. What do you guys recommend using? I am using DIYLEDEXPRESS PixelBulbs to outline my house (My first year) they say they use 18 AWG wire. I figure I would just use 18AWG to keep the same thickness. Looking for good options. Also if it makes a difference I am using ESPixelSticks for my data.
    Thank You
    Chambersburg, PA
    707
    Default Re: Which type of Wire to use
    First thing. Make sure whatever you use is 100% copper wire. You will see a lot of CCA (Copper Clad Aluminum) wire out on the market. It is not as efficient at moving power as pure copper.
    I use Monoprice speaker wire for my power and data runs. I keep a supply of 2 conductor 18AWG and 4 conductor 16 AWG on hand. I will use the 4 wire to run power and data(3 wire), and also use it to do two Power Injection runs.
    2016 - No Display
    Nov 2014
    Close to Hillsboro, OR
    480
    What he said. This year I bought spools of the LED power wire, in 3-conductor (18ga) and 2-conductor (16ga). They are both 100% copper and can easily be found on Amazon.
