Make sure that at the top of the tree you are using data plus V- as you go from strip to strip. You cant count on the inter-strip ground at the bottom of the tree to provide the data reference path. It is too far away. I also noticed that at the bottom of the tree you do not have a dedicated signal ground between strips. This will be ok if you are keeping the power injection wires between the strips short (less than a few feet). If you are actually doing a run back to the PSU at the bottom of each strip then you will need a V- wire running in parallel with the data wire between the strips.
