Results 1 to 2 of 2
Thread: tie wrap thoughts
    Apr 2019
    Justin Texas
    80
    Default tie wrap thoughts
    I have built 3 mini trees with mini lights attached with tie wraps. Each tree has about 100 tie wraps. I have not cut the tag end of the tie wraps yet. As I look at them all the tie wraps ends are sticking directly out from the mini tree. It kind of gives it a prickly look. Does anyone have thoughts on just leaving the tie wraps uncut? has anyone gone for the prickly look before?
    Southern California
    1,079
    Default Re: tie wrap thoughts
    nobody will likely see them in the dark. if visible when lights are lit, i would cut them.
    Kevin
