Thread: Cable advice
    Nov 2018
    Houston, Texas
    149
    Default Cable advice
    Was in my attic putting up Halloween display and noticed a box in the dark corner so hereís what I found ... full box
    Will this be of use when I make the switch to pixels ? Iíve read several discussions on cat5 and many say no cca but donít see that on label so not sure . Any help appreciated as I know many are busy as I am aswell .
    May 2010
    ottawa , ontario, Canada
    1,752
    Default Re: Cable advice
    cat 5 are good for data and can go long ( i have 50 ft run ) .. and some used them for voltage too on short run by pairing them up ,, like 1 wire for data ,,, then paire the rest for ++ and--- it is not recommended but some people have success with it
    cheer
    1,484
    Depending on your controller, it can be used for Ethernet runs from a switch to the controller/Pi/PC or if you have something like a Falcon F48 where you need a cat5 type cable to run from the controller to the receiver boards this will be good. It states that it is Verified Cat5 not Cat5e so if you are wanting GB network speeds, it could be questionable.
    Or as Barbotte said it can be use for long data runs from the controller to pixels directly.
