Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Looking for small (1' tall?) antenna design
    Anchorage, AK
    341
    Default Re: Looking for small (1' tall?) antenna design
    I used to do that with CB and Marine Vhf radios in aircraft. I cut at 1/8" increments for both. Does'nt take much to make a big change when you get close.
    SF Bay Area
    788
    What about coil separation, pitch and diameter? Those parameters were crucial in the formulas I found online.
    Jun 2015
    75
    Look for examples on the 2 Meter HAM antennas, 2 Meter is around 144Mhz, FM radio band is around 2.7(3) meter wave length.
    Anchorage, AK
    341
    These were premade antennas, they had the wire straight at the end, and you cut for minimum vswr. As far as antenna design, that is best left to an antenna engineer. I do think we are over thinking this though. Test with a cheap transmitter, then move over to your more expensive transmitter.
    Nov 2013
    88
    If you can measure low VSWR at the frequency of interest then you should not be able to harm the transmitter as you are not reflecting the power back.
    Low VSWR does not promise the devised antenna is a good radiator, the receiver end has to tell you that.
    A 50 or 75 ohm resistor will give you a good VSWR but rarely act as a great antenna.
