Results 1 to 10 of 20
Thread: Router Question about internet and networking
    Oct 2015
    Hastings, New Zealand
    46
    Default Router Question about internet and networking
    Long story short.
    I replace my Huawei ISP router with a Flash and fancy Dlink EXO DIR 879 router. I cannot for the life of me get it to connect to any of my D1 Wemos boards.
    I have read (somewhere) it's better to run the show off a seperate router anyway. So I'm going to use the Huawei modem which has been working with the nodes.
    My question is, Will I need to connect the Huawei to the internet, or can I run it as a local 'server'? as when i connect it back up with the same wifi protocols as before the light won't go.
    I can ping successfully both the router and the D1 Wemos so they all see each other, but I can't figure out why the lights won't turn on any more since the change.
    Thanks in advance.
    Folsom, CA, USA
    1,987
    Default Re: Router Question about internet and networking
    Are you using the same SSID on both routers - don't
    In Lights Therapy
    1,484
    Are you using the same Subnet on both - change one! 192.168.x.x and 192.168.x+1.x (or any # for the 3rd Octet so that each subnet is unique.
    6,081
    Have you tried multicast rather than unicast on your Wemos ?
    Folsom, CA, USA
    1,987
    Quote Originally Posted by nzchristmas.nz View Post
    ….I have read (somewhere) it's better to run the show off a seperate router anyway. So I'm going to use the Huawei modem which has been working with the nodes.
    Yes, that is correct
    ….My question is, Will I need to connect the Huawei to the internet, or can I run it as a local 'server'? as when i connect it back up with the same wifi protocols as before the light won't go.
    You do not need internet connection.
    In Lights Therapy
    Oct 2015
    46
    They are separate SSIDs
    Oct 2015
    46
    Both separate. My main one is 192.168.0.x and my lights one is 192.168.1.x
    Oct 2015
    46
    nope. all set up for unicast. I could try that. but I thought Unicast was better?
    6,081
    Multicast better suited for wireless . I have my router set a AP and is connected to a dhcp router with internet connection no issues.
    I will use a seperate router for show only . Router ip is 192.168.1.1 with all wemos set to 192.168.1.*
    no issues.
    Folsom, CA, USA
    1,987
    Actually, for WiFi devices, Multicast is best.
    Do you have a spare WeMos you can give a fresh flash, ensuring the correct SSID and Password are configurated.
    In Lights Therapy
