Thread: Model 3B vs 3B+
    Oct 2018
    7
    Default Model 3B vs 3B+
    Is there a significant difference in performance when running FPP on either of these two? I currently have a 3B+ that runs my home automation server (Hass.io) and just came into a 3B for cheap. Is the gigabit ethernet of the 3B+ going to make enough of a difference to warrant swapping or am I fine to continue with my plan to use the 3B for FPP?
    Nov 2014
    Close to Hillsboro, OR
    425
    Default Re: Model 3B vs 3B+
    I have used a 3B to run my entire show with absolutely zero issues. However, to be transparent, that 3B feeds directly into a network switch as my show is run via cables, not WiFi.
    Oct 2018
    7
    Ok good to hear. Was planning on connecting the pi to a dedicated router via cable, but then many elements would be via WiFi. In that arrangement, I'm hoping wireless performance is dictated by the router not the pi.
    Sent from my SM-N950U using Tapatalk
